Strange current
  • Thread starter Chemist@
Chemist@
115
How is the current that pushes electricity through the space between the two plates of the capacitor called?
Answers and Replies
Stephen Tashi
1,534
Are you thinking of "displacement current"?
Chemist@
115
Yes, thank you.
Chemist@
115
How is this current connected to the turbulent current and the surface current?
Svein
Insights Author
2,242
765
No current is flowing "through" the capacitor. Current flowing onto one plate creates a charge which sets up an electric field which again repels some charge on the other plate. Therefore you can "load" the capacitor with a charge by connecting it to a voltage source. You can then transport this charge by disconnecting the capacitor and moving it somewhere else.
Likes davenn
Chemist@
115
But why and how does AC pass through the capacitor?
davenn
2021 Award
9,625
8,841
It doesn't, because AC is cycling, the polarity of the charge on each of the plates of the capacitor is also constantly alternating
at the frequency of the AC signal (voltage)
Dave
Svein
Insights Author
2,242
765
It does not. An alternating current will charge and discharge one plate, which means that the electrical field will change which again will change the charge on the other plate. A change in the charge means that a current will pass out of or come onto the plate. Thus, it seems as if current "passes through", but in reality it is interaction between current, charge and field.
To repeat the basics: Q = C*V. If things change over time, you get dQ/dt = C*dV/dt, and dQ/dt is the current out of or onto the plate.
Suggested for: Strange current
  • Last Post
  • Last Post
  • Last Post
  • Sticky
  • Last Post
  • Last Post
  • Last Post
  • Last Post
