Why Does This Number Pattern Have a Strange Repeating Sequence?
  • Thread starter KLscilevothma
  • Tags
    Strange
In summary: The question is (translated to English by me):[1] Is there a positive integer N, such that for any prime p not bigger than N, p|10^N+1?I've solved it but I don't think it's necessary to post the solution here. But I think there's a connection between this and Hurkyl's observation. This reminds me of a very similar problem:[2] Is there a positive integer M such that for any prime p not bigger than M, p|10^(M-1) - 1?This is a somewhat famous question, which is the case 10^n - 1.In summary, we
KLscilevothma
322
1/7 = 0.142857142857...
2/7 = 0.285714285714...
3/7 = 0.428571428571...
4/7 = 0.571428571428...
5/7 = 0.714285714285...
6/7 = 0.857142857142...
That's strange.
Mathematics news on Phys.org
why...
is that?
All fractions repeat or terminate eventually.
Here, we know it will repeat after n digits if 10^n / 7 = whole number + 1/7.
ie, 10^n = 1 (mod 7)
true for n=6
10^6/7 = 142857 + 1/7
why strange?
Does this also mean that PI will terminate sooner or later?
By fractions he meant one whole number divided by another one. There are numbers (irrational numbers) that can't be gotten that way. Square root of 2 and pi are a couple of well known ones. Their decimal expansions are non-repeating.
All RATIONAL numbers can be represented as a repeating or finite length decimal. A rational number is one which can be represented as a ratio of 2 integers. Thus all fractions and integers.
Pi OTH is not a rational number, it is a irrational, so cannot be represented as a finite length or repeating decimal.
The Real number system is composed of both the rational and irrational numbers.
This is an interesting
but well studied observation. All the numbers that divide into 99 repeat after a period of at most two, all that divide into 999 by at most three, ect., so that means that seven divides into 999999. Other numbers systems also work this way, nothing peculiar about base ten. If you have a sequence of 1's that is a prime number, then multiply it by 9, then it's only factors are the prime× 3×3, and the prime will divide with the period of the sequence length.
Orginally posted by damgo
true for n=6
Fermat's little theorem. :wink:
So why's there rotation of the digits when a/7 (a isn't 7's multiple)
Orginally posted by Integral
|[rr]| < |Q| (where Q stands for set of rational numbers)
I've heard that pi, e, golden ration, etc are trancedental(sp?) numbers, but the proof is far beyond my level.
as you can see, the numbers only contain "142857" and they are rotated in a periodic manner. (I've edited my first post a bit)
Try performing the long division necessary to get the digits.
One you might notice is that there are only a finite set of possible remainders, and any particular remainder is always followed by the same next remainder. It's easy to see why; at each step you add a 0 and divide again, so same remainder means same next step.
For example, I'll do it with 7 (with somewhat modified notation; I hope it's clear):
7 | 1 -> 0 R 1
7 | 10 -> 0.1 R 3
7 | 30 -> 0.14 R 2
7 | 20 -> 0.142 R 6
7 | 60 -> 0.1428 R 4
7 | 40 -> 0.14285 R 5
7 | 50 -> 0.142857 R 1
7 | 10 -> 0.1428571 R 3
The sequence of remainders will repeat forever (1, 3, 2, 6, 4, 5), which will forever generate the sequence of digits (142857).
There are only 7 possible remainders when you divide by 7; 0, 1, 2, 3, 4, 5, and 6. The last 6 of them are in the above cycle, so any time you get one of those remainders, the following digits will follow that cycle. The only other possibility is that 7 evenly divides the number in question (such as 14 / 7), where there is only one remainder in the cycle (0) and the sequence of digits is simply an infinite string of 0's.
Every other number behaves similarly, except 7 is somewhat special by having one large cycle of non zeroes. For example, with the number 4:
Starting with a remainder of 0, 00 / 4 = 0 R 0, so remainder 0 progresses to remainder 0 yielding digit 0
Starting with a remainder of 1, 10 / 4 = 2 R 2, so remainder 1 progresses to remainder 2 yielding digit 2
Starting with a remainder of 2, 20 / 4 = 5 R 0, so remainder 2 progresses to remainder 0 yielding digit 5
Starting with a remainder of 3, 30 / 4 = 7 R 2, so remainer 3 progresses to remainder 2 yielding digit 7
So, if you were computing something like 3/4, you get a remainder of 3, which yields remainder 2 then an infinite sequence of 0's, which gives the digits 7, 5, 0, 0, 0...
i.e. 3 / 4 = 0.75000000...
Other numbers have different cycle structures. 6 has several cycles, which can be observed in its somewhat interesting diversity of expansions:
0/6 = 0.00000...
1/6 = 0.16666...
2/6 = 0.33333...
3/6 = 0.50000...
4/6 = 0.66666...
5/6 = 0.83333...
The number 11 has a whole buch of two cycles, yielding the familiar expansions:
1/11 = 0.090909...
2/11 = 0.181818...
3/11 = 0.272727...
et cetera
The number 13 is more similar to 7; it yields two separate 6-cycles, but not a 12 cycle (of course, it also has the trivial all 0's cycle). The two corresponding patterns are:
(076923) and (153846)
And any decimal expansion of a fraction with denominator 13 will end in a repeating sequence of one of those cycles of digits. For example:
4/13 = 0.3(076923)07692...
I don't know if any larger numbers have a complete cycle like 7 does; it has been a long time since I played with this, and I don't think I went past 13.
Thanks Hurkyl, that's interesting.
well in fact I've come across a question from a math contest(group section), which initiated me to start this post.
Question :
Given that abcdef is a six digit number(each letter represents one digit) and all of them are distinct and non of them equals 0. Find abcdef. As a remark, abcdef can be uniquely determined.
bcdefa=2*abcdef
cdefab=3*abcdef
defabc=4*abcdef
efabcd=5*abcdef
fabcde=6*abcdef
My friend knew the special number 142857 and wrote it down immediately, but I'm thinking what if we don't know 142857, how can we tackle this problem?
By the way, hmm... for example the fraction 5/99783, as it is a rational number, there must be a repeating cycle, right? Can we determine how many digits later will the repeating cycle emerge? I think I've heard that(long long long time ago and I'm not sure whether this memory of mine's valid!) we can proof that the number of digits before the repeating part of a rational fraction emerges doesn't exceed N, where N is a very large number. (I hope you got what I mean!) Has anyone heard of it also ?
Hrm, you're misstated the problem; the problem you stated has no solution.
proof:
Because efabcd=5*abcdef, d must either be 5 or 0. Since d isn't allowed to be 0, d is 5, and f must be odd.
defabc=4*abcdef and fabcde=6*abcdef imply that
fabcde = (3/2)*defabc < (3/2)*599999 < 900000
so f < 9
However, fabcde = (3/2)*defabc implies that f >= d, so f = 7.
Now that we know f = 7, we can find all the other digits:
a = 2 * f mod 10 = 4
b = 1
c = 8
d = 5
e = 2
so the number (if it exists) must be 418527, but you can easily check it doesn't work. (in particular, you can easily show from the problem you stated that a<b<c<d<e<f)
I think I've heard that we can proof that the number of digits before the repeating part of a rational fraction emerges doesn't exceed N, where N is a very large number.
N, in fact, is the number we're dividing by!
When you divide something by x, there are only x possible remainders, so you cannot possibly have more than x digits before the first digit of a repetition.
I don't see how its possible for the letters to equal anything
Say:
a = 4
b = 1
c = 8
d = 5
e = 2
f = 7
Now the problem is:
bcdefa=2*abcdef
cdefab=3*abcdef
defabc=4*abcdef
efabcd=5*abcdef
fabcde=6*abcdef
now if we put in the variables it would be:
(1*8*5*2*7*4)=2*(4*1*8*5*2*7) =
2240=4480
Thats not right, is it?
For the problem (as described), a string of variables is supposed to mean that each variable represents a digit of the number, not that you multiply the variables.
modified question
Question :
bcdefa=2*abcdef
cdefab=3*abcdef
defabc=4*abcdef
efabcd=5*abcdef
fabcde=6*abcdef
Modified question:
cdefab=2*abcdef
bcdefa=3*abcdef
efabcd=4*abcdef
fabcde=5*abcdef
defabc=6*abcdef
Thanks Hurkyl, clear explanation!
I'm drilling a hole...
Yes, that is why
999999/7 = 142857
gotcha, thanks.
1. What is a "strange number pattern"?
A strange number pattern is a sequence of numbers that follows a specific rule or pattern that may seem unusual or unexpected at first glance. It can be found in different areas of mathematics and can have various applications.
2. How can you identify a "strange number pattern"?
In order to identify a strange number pattern, you need to carefully observe the sequence of numbers and look for any recurring patterns or relationships between the numbers. This can involve using mathematical operations, graphing the numbers, or looking for common factors or multiples.
3. What causes a "strange number pattern" to occur?
Strange number patterns can occur due to various factors such as mathematical rules, natural phenomena, or human-made constructions. They can also be a result of chance or coincidence.
4. Can "strange number patterns" be found in real-world situations?
Yes, strange number patterns can be found in real-world situations such as the Fibonacci sequence in nature, the Golden Ratio in art and architecture, or the recurrence of prime numbers in cryptography and computer science.
5. How can understanding "strange number patterns" be useful?
Understanding strange number patterns can be useful for solving mathematical problems, predicting future outcomes, and gaining a deeper understanding of the world around us. It can also have practical applications in fields such as engineering, finance, and data analysis.
  • General Math
  • General Math
  • General Math
