Strength and direction of an electric field at a particular point problem
In summary, the conversation discusses the calculation of the electric field at a specific point in a figure with multiple charges. The conversation also delves into finding the direction and strength of the electric field, and includes equations and attempts at solving the problem. There is some confusion and questions about how to factor in the negative charge, and the conversation ends with a request for clarification and help with solving the problem correctly.
Netsurfer733
Hello all - this is my first time giving this forum a try. I've been using another site for a while but it's just too spotty and not enough folks there care to give decent responses, so here I am :)
http://img684.imageshack.us/i/27p28.jpg/
What are the strength and direction of the electric field at the position indicated by the dot in the figure?
a) Give your answer in component form. (Assume that x-axis is horizontal and points to the right, and y-axis points upward.) Express your answer in terms of the unit vectors i and j.
b) Give your answer as a magnitude and angle measured cw [Edit: ClockWise?] from the positive x-axis.
c) Give theta, the degrees clockwise from the positive x axis.
E_1x = E_1*cos(theta) = k*(q1 / r1^2) * cos(theta)
At least, I believe this is the main equation you need...?
The book I'm using is confusing about this. I've tried the idea of calculating the fields for each of the points (the two positive charges and the electric charge), but as far as the angles go and how the negative charge will pull away from the rest of those charges...I start to get a headache. How does that factor in with the rest of the angles? Does it, perhaps, pull away straight up and leave the x components of the other one to push it out? Why am I not getting the right answer for that then when I try it, in such a case... Does anyone have an idea?
Yes, the electric field of the negative charge points up at P. However, you don't need to worry about this. Since Ex=kq/r^2 * cos(theta), you can simply insert the negative charge into q and get the right answer. There's nothing special in the equation that makes it only work for positive charges.
Can you show all your work? It might just be an algebra mistake.
Well I actually just think I might be on the right track for these parts at least...though honestly I'm really quite confused still, having not done anything like this in years (you'll see that from my work, I'm sure...). My work:
<Note: I've labeled the charges as such: E1 is for the field from the lower left charge, E2 from the upper left, and E3 from the upper right>
E_netx = E_1x + E_2x
E_1x = 9*10^9 * 5*10^-9 / 0.02^2 = 112500 N/C
E_2x = 9*10^9 * 10*10^-9 * cos(63.4degrees) / 0.045^2 = 1990 N/C
Therefore E_netx = 114490 N/C
E_nety = E_2y + E_3y
E_2y = 9*10^9 * 10*10^-9 * cos(26.6) / 0.045^2 = 3974 N/C
E_3y = 9*10^9 * (-5*10^-9) * cos(0) / 0.04^2 = -28125
Therefore E_nety = 3974 - 28125 = -24151 N/C
...and honestly I have no idea what to do with this information o.o I'd need to find the overall angle as to where the direction of that field would go, and for some reason I'm just not getting that. How horribly wrong am I, and what can I do to correct myself and push forth?
1. What is the concept of an electric field?
The electric field is a fundamental concept in physics that describes the force exerted on a charged particle by other charged particles. It is a vector quantity, meaning it has both magnitude and direction.
2. How is the strength of an electric field measured?
The strength of an electric field is measured using the unit of volts per meter (V/m). This unit represents the amount of force (in volts) exerted on a charge of one coulomb at a distance of one meter from the source of the field.
3. What factors affect the strength of an electric field at a particular point?
The strength of an electric field at a particular point is affected by the magnitude and distribution of the source charges, as well as the distance from the source charges. It is also influenced by the presence of other charged particles in the surrounding environment.
4. How is the direction of an electric field determined?
The direction of an electric field is determined by the direction of the force that would be exerted on a positive test charge placed at that point. The field lines always point in the direction of the force that would be experienced by a positive charge.
5. How can the strength and direction of an electric field be represented mathematically?
The strength and direction of an electric field can be represented mathematically using vector notation. The magnitude of the electric field is represented by the magnitude of the vector, while the direction is represented by the direction of the vector. The electric field can also be represented by electric potential, which is a scalar quantity.
