What is the Optimal Thickness for 4x4 Steel Tubing in a Giant Monkey Bar Set?
In summary: TK9320: I think the steel square tube minimum tensile yield strength is probably Sty = 275 MPa. You could use a yield factor of safety of FSy = 1.50. Therefore, for your 101.6 x 101.6 x 4.7625 mm...The minimum yield strength for steel square tubing is Sty = 275 MPa. With a yield factor of safety of FSy = 1.50, the 101.6 x 101.6 x 4.7625 mm steel square tubing would have a strength of 5,275 MPa.
TK9320
I'm building a giant set of monkey bars for a gym and I'm curious about the strength of material I plan to use.I'm going to use two 4x4 3/16 thick steel tubing that will run 20 feet long and sit on top of the same material at each end 9 feet high.I will brace the top corners at each end.
I'm curious if 3/16 will work or should I use 1/4 inch thick?
It won't have any large loads on it.It's just for chin up bars and maybe a punching bag hanging from it. Thanks for your help.
TK9320: I think 12 to 15 people could easily fit in this space doing chin-ups simultaneously. Please let us know the maximum number of people that can fit in this space.
There will 10 chin up bars on each end.They will only be 7 ft from the end,so they won't be in the center.There may be an 80lbs punching bag in the center.
I don't think they will ever have 20 people on it at the same time though. Thanks
TK9320: What is the distance between your two horizontal beams?
they will be 52 inches apart with 1.25 OD round tubing for the bars,drilled through the 4 inch
OK, I misinterpreted something earlier. My fault. Let me make sure I understand. You have two horizontal beams, 52 inches apart. And these two beams have one chin-up bar on each end, located 7 feet from each end. Therefore, the distance between the two chin-up bars is 6 feet. Plus, there is a punching bag bar in the center. And we can call this one "frame." It sounds like you have five of these frames, side by side, in the room, correct? Therefore, does each adjacent frame share a horizontal beam? In other words, you have six horizontal, 20-foot-long beams in the room, right? And each of the six 20-foot beams sits on a vertical 4 x 4 inch tube at each end, correct?
There are only two 20 ft 4x4s with two 4x4s at each end 9ft high.There are two bars at each end one 3ft from the end and one 7ft from the end.There will two other bars that run horizontal on each side.So at each end there are two bars between the beams and two on the outside.So 6 total at each end.
nvn said:
I cannot imagine, yet, how there are ten chin-up bars on each end. By the way, did you know you can https://www.physicsforums.com/showthread.php?t=433015#post2906520" a diagram when you post? You could scan (or photograph) a freehand sketch, or draw a rough diagram using Start > Programs > Accessories > Paint, if you wish.
There are six at each end.I took some pics of my sketch but the file is too big to upload.I can email them you want.
Try going to the link I posted, then click the imageshack link, then upload your pictures. I think you can use the "image resize" pull-down menu in imageshack, if you wish. But it is probably not required. Then post direct links to the pictures.
http://img693.imageshack.us/img693/6169/sketch2h.jpg
http://img219.imageshack.us/img219/694/sketch1.jpg
TK9320: Nice job uploading the diagrams. Assuming up to 20 people are doing chin-ups simultaneously, with an average mass per person of 91.8 kg, and assuming one punching bag in the center, I think you can use a dynamic amplification factor of daf = 2.0. I think the steel square tube minimum tensile yield strength is probably Sty = 275 MPa. You could use a yield factor of safety of FSy = 1.50. Therefore, for your 101.6 x 101.6 x 4.7625 mm square tubes, we have the following.
L = 6100 mm, M = 6.1803e6 N*mm, I1 = 2.8902e6 mm^4.
sigma = daf*M*c/I1 = 217.26 MPa.
Ry = FSy*sigma/Sty = 1.50(217.26 MPa)/(275 MPa) = 118.5 %.
Ry > 100 % indicates the two beams are currently overstressed using 101.6 x 101.6 x 4.7625 mm steel tubes.​
For your 101.6 x 101.6 x 6.35 mm square tubes, we have the following.
L = 6100 mm, M = 6.1803e6 N*mm, I2 = 3.6745e6 mm^4.
sigma = daf*M*c/I2 = 170.89 MPa.
Ry = FSy*sigma/Sty = 1.50(170.89 MPa)/(275 MPa) = 93.2 %.
Ry ≤ 100 % indicates your two beams are currently not overstressed using 101.6 x 101.6 x 6.35 mm steel tubes.​
Therefore, if you want to use 101.6 x 101.6 mm square tubes, then it appears they would need to have a wall thickness of 6.35 mm.
By the way, it appears your structure needs to be stabilized in the lateral direction. No end view is shown, so we do not know if you provided a corner brace on the ends.
The above results assume no one is hanging (bouncing) on the structure near midspan, which might be an unwise assumption.
Thanks.How does it work out if only 12 people max would be on it at one time?
It depends on where they are hanging. More people near midspan creates higher stresses.
I can make the structure fail using 14 people, 101.6 x 101.6 x 6.35 mm steel tubes, and daf = 2.0. I put two people on the bar holding the punching bag, one person on each beam at x = +/-450 mm from midspan, two people on each chin-up bar at x = +/-914 mm from midspan, and one person on each outside chin-up bar at x = +/-1524 mm from midspan. This gives the following stress level (and I haven't even subtracted for the holes in the beam).
M = 7.2828e6 N*mm, sigma = daf*M*c/I2 = 201.37 MPa.
Ry = FSy*sigma/Sty = 1.50(201.37 MPa)/(275 MPa) = 109.8 % > 100 %.​
However, I think using daf = 2.0 for all people simultaneously is conservative, and can be reduced to daf = 1.75, which gives the following.
M = 7.2828e6 N*mm, sigma = daf*M*c/I2 = 176.20 MPa.
Ry = FSy*sigma/Sty = 1.50(176.20 MPa)/(275 MPa) = 96.1 % < 100 %.​
Therefore, if you want to use 101.6 x 101.6 mm square tubes, this still indicates they would need to have a wall thickness of 6.35 mm.
Or, you might want to try 152.4 x 101.6 x 4.7625 mm rectangular tubes (which I have not tried). Post the material specification for your tubes, if you have it.
TK9320: However, the results in post 15 do not include self weight. When we include self weight, the second Ry in post 15 becomes Ry = 106.5 %, which indicates the two square beams are overstressed. It seems you need to use 152 x 102 x 4.763 mm rectangular tubes for your two horizontal beams. These would have the same weight as the square tube beams in post 15, but would instead give the following results for the post 15 load case using daf = 1.75, except including self weight.
L = 6100 mm, M = 8.3974e6 N*mm, I3 = 7.5903e6 mm^4.
sigma = daf*M*c/I3 = 147.53 MPa.
Ry = FSy*sigma/Sty = 1.50(147.53 MPa)/(275 MPa) = 80.5 % < 100 %.​
1. What is the strength of 4x4 steel tubing?
The strength of 4x4 steel tubing is measured in terms of its yield strength and ultimate strength. Yield strength is the amount of force required to permanently deform the tubing, while ultimate strength is the maximum amount of force the tubing can withstand before breaking. The specific strength of 4x4 steel tubing can vary depending on the type and grade of steel used, as well as the wall thickness of the tubing.
2. How is the strength of 4x4 steel tubing determined?
The strength of 4x4 steel tubing is determined through testing and analysis. The tubing is subjected to various types of stress and strain, and the resulting data is used to calculate its yield strength and ultimate strength. These tests can be conducted in a laboratory setting or through computer simulations.
3. What factors affect the strength of 4x4 steel tubing?
The strength of 4x4 steel tubing can be influenced by several factors, including the quality and grade of steel used, the thickness and diameter of the tubing, the manufacturing process, and any external factors such as temperature and corrosion. The design and construction of the structure using the tubing can also impact its strength.
4. How does the strength of 4x4 steel tubing compare to other types of steel tubing?
4x4 steel tubing is generally considered to be a strong and durable option for structural applications. However, its strength may vary compared to other types of steel tubing, such as rectangular or round tubing. The specific strength of the tubing will depend on its size, grade, and intended use.
5. What is the maximum weight that 4x4 steel tubing can support?
The maximum weight that 4x4 steel tubing can support will depend on various factors such as the type and grade of steel used, the wall thickness of the tubing, and the design of the structure. It is important to consult with a structural engineer to determine the appropriate weight and load capacity for your specific application.
  • Mechanical Engineering
13K
  • General Engineering
16K
10K
9K
