Stress in a pipe wall
Ebi
Consider a pipe. The pipe is not crushed by the air pressure because the same air pressure is acting from inside the pipe. But this means that the material of the pipe is being compressed on both sides by some air pressure. So is it correct to say that the through-thickness stress in the pipe would be the same as the air pressure?
Answers and Replies
BvU
2019 Award
13,515
3,246
yes
Likes Chestermiller
Yes, but its insignificant. Most material strengths are rated in MPa. The measly 101.325 kPa we've got as air pressure is hardly a challenge. Thats why it's just ignored...
Baluncore
2019 Award
7,955
2,846
The wall will be thickest when the open pipe is in a vacuum.
The wall will become progressively thinner as the open pipe is subjected to greater hydrostatic pressures.
10,796
Just like for every other material around us (with very few exceptions), yes.
Ebi
Thanks for your response. What you said is intuitive but if you look at link below, for Pi=Po, it seems stress through the thickness varies with the radius r.
https://www.engineeringtoolbox.com/stress-thick-walled-tube-d_949.html
I am not sure if I am missing something.
Baluncore
2019 Award
7,955
2,846
If you go to the calculator at the bottom of the referenced page, and enter zero internal and external pressure, you get zero stress.
Likes Ebi
Baluncore
2019 Award
7,955
2,846
The r, or term disappears for zero pressure difference.
σr = [(Pi·Ri² - Po·Ro²) / (Ro² - Ri²)] + [Ri²·Ro²· (Po - Pi) / ( r²· (Ro² - Ri²))]
Likes Ebi
10,796
... and the first term simplifies to -Pi. Or -Po, same thing. Which means radial compression is simply the common pressure on both sides, as expected.
Likes Ebi
Related Threads on Stress in a pipe wall
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
