How to Calculate Work Done in Extending a Material to Breaking Point?
In summary: So the rod will be stretched a lot, but it won't take 0.6 J of work to do so.And a strain of 0.4? That is large and will result in a large change of cross sectional area. So the rod will be stretched a lot, but it won't take 0.6 J of work to do so.
EskShift
A material has a stress of 60,000Pa and a strain of 0.4 at breaking point.
Given that it is in the shape of a 2m long cylinder of radius 20cm, what work had to be done to extend the material to the point of fracture?
Well i thought work done was equal to the area under the graph.
Therefore: 0.5 x 60,000 x 0.4 = 12,000 J
Apparently answer is 0.6 J, so I am fairly off. any ideas?
surely someone can help!
All I can tell you is that in order to make it equal to .6 J, you need to multiply the given stress and strain by .000025. But, you may have already known that. As for how to get that... no idea. Sorry. :frown:
Ohhh... nevermind. I posted to late. :biggrin:
LowlyPion said:
thats still fairly confusing!
the change in length is 0.8m, the original length is 2m, stress is 60,000Pa at point of fracture and Strain is 0.4 at point of fracture, radius of the cylinder is 20cm and i need to find the work done to extend the materials to the point of fracture.
Work = Fx right?
but what values do i use?
Eskshift look at the article again. You have all of the information needed. What else do you need. And work is most accurately described as [tex]\int F ds[/tex] Where F in this case is [tex]\frac{EA}{L_0}[/tex] and is done over the change in length...
Well that gave me about 3000+, and the answer says 0.6 J, so either the answer is a mistype or its the wrong equation.
Looks like you or the answer slipped a few decimal points. Like maybe the answer is 6 kJ? Also, the answer, if 6 kJ, appears to be off by a factor of 2, since I get 3 kJ, which agrees with your 2nd answer. It seems like they took work as equal to Fx, whereas, since you must calculate Work = the integral of Fx, where F varies from 0 to F, this implies W=F/2(x). The work done is NOT the area under the stress strain graph. It is the area under the force-displacemnt graph.
And if Wiki confuses you, welcome to the club.
The volumetric work done is the area under the stress-strain graph, though. EskShift made a units error in the first post: [itex]\mathrm{Pascals}\neq\mathrm{Joules}[/itex].
By multiplying the volumetric work by the volume, I get 3.02 kJ if the stress is assumed to have increased linearly up to the failure point.
Think about this, have you ever tried to stretch 2m long circular rod? The only way it would ever take 0.6J is if it were made of paper and in that case the sigma yield would not be 60000Pa.
Its always good to think about the question and what the answer implies.
A hydrogel fits [itex]\epsilon = 0.4 [/itex] and [itex]\sigma_\mathrm{fail}=60\,\mathrm{kPa}[/itex] pretty well. But I agree that the 0.6 J value doesn't fit at all.
1. What is the definition of stress and strain?
Stress is the force applied to a material, while strain is the resulting deformation or change in shape of the material.
2. How are stress and strain related?
Stress and strain are directly proportional to each other, meaning as one increases, the other also increases. This relationship is described by Hooke's Law.
3. What are the different types of stress?
The three main types of stress are tensile stress, compressive stress, and shear stress. Tensile stress pulls on a material, compressive stress pushes on a material, and shear stress causes one part of a material to slide past another.
4. How does stress and strain affect different materials?
The amount of stress a material can withstand before breaking or permanently deforming varies depending on the material's properties, such as its composition and structure. Some materials, like metals, can withstand high levels of stress, while others, like ceramics, are more brittle and have lower limits.
5. How is stress and strain measured?
Stress is typically measured in units of force per unit area, such as pounds per square inch (psi) or newtons per square meter (N/m2). Strain is measured as the change in length or shape of a material divided by its original length or shape, and is usually expressed as a percentage.
