Strings in C
  1. Jan 18, 2009 #1
    Ok, i need to make a program that will search for a substring in a given string, and replace it with another one.
    3. The attempt at a solution
    Code (Text):
    #include<stdio.h>
    #include<iostream>
    #include<string.h>
    using namespace std;
    int fsubstitute(char *ulazni, char *prvi, char *drugi);
    int main()
        char initial[255];
        char find[255];
        char replace[255];
        gets(initial);
        gets(find);
        gets(replace);
        fsubstitute(initial,find,replace);
    int fsubstitute(char *initial, char *find, char *replace)
        char *temp1;
        int i,j,k,c,l,n;
        i = j = k = c = l = n = 0;
        n = strlen(find);
        l = strlen(initial);
        char temp2[200];
        do{
            if(strstr(initial,find)!= NULL)
            temp1 = strstr(initial,find)+ n;
            for(i=0;i<l-strlen(temp1)-n;i++)
            temp2[i] = *(initial+i);
            temp2[i] = '\0';
            initial = temp2;
            initial = strcat(initial,replace);
            initial = strcat(initial,temp1);
        }while(strstr(initial,find)!= NULL);
        cout << initial << endl;
        return 0;
    I used cout since it is easier to write, and that's why i included a c++ library/
    Can you tell me what's wrong with my code?
  3. Jan 18, 2009 #2
    D H
    Staff Emeritus
    Does it compile? If not, what is the message?
    If it does compile, does it compile clean with all warnings enabled?
    Have you used a debugger? If so, where did your code behave other than you expected?
    If you haven't used a debugger, why not?
  4. Jan 18, 2009 #3
    I mean everything's fine with the syntax, it just won't do its job.
  5. Jan 18, 2009 #4
    D H
    Staff Emeritus
    So, have you debugged your program? Do you even know what that means?
    We treat computer programming problems here the same as physics homework problems: You have to show your work. In the case of a computer program, showing your work means you telling us a bit about the execution of your program. We don't do physics homework for students because that is a disservice. The same goes for us debugging your program for you.
  6. Jan 18, 2009 #5
    I solved it, thanks for the help anyway.
  7. Jan 18, 2009 #6
    D H
    Staff Emeritus
    Does your program work for nasty cases, for example initial="this is a test", find="is", replace="this"?
  8. Jan 18, 2009 #7
    Yes it does :)
