Strong or weak acid?
  • Thread starter Physics197
How can you determine if an acid is strong or weak given the titration curve? I need two reasons.
1 Reason that it is weak is that its being titrated by a strong base and the equivalence point is above pH of 7.
Need a 2nd
Answers and Replies
Borek
Mentor
28,808
3,308
Take two titration curves and compare them.
You may try (there is a free trial).
Not sure what the acid is, but through a tritaion calculation I found the concentration of the acid to be 0.2083M.
That may not be correct..
Heres the data:
NaOH: 0.125M
25mL
acid: 15mL
unknown concentration
But it is a monoprotic acid
symbolipoint
Education Advisor
1,284
Depending on concentrations used, pH will change at a very high rate through pH 7 through the equivalence point. A weak acid will further show fairly small change in pH as the titrant is added over a "long" range of titrant addition until close to the equivalence point. Equivalence point should happen at about pH 8 or greater for a weak acid.
Yes, it happens at pH = 8.7
It just occured to me that weak acids do not 100% dissociate
So could I use the pH of 8.7 to determine the concentration of H+ and compare that number to the concentration of the acid, and if they are different, that means it wasnt 100% dissociated?
HX ---------> H+ + X-
0.2M -------> 2x10^-9M
[H+] = 10^-pH = 2x10^-9
Borek
Mentor
28,808
3,308
At equivalence point there is (almost) no acid, there is (almost) only its salt.
Well whats another way I could show that this acid is weak?
symbolipoint
Education Advisor
1,284
You just did, according to some of your description in post #5.
Was the original acid available in relatively pure, dry form? Even a pH measurement before titrating might not be strong enough information compared to performing a titration. As long as you can refer to your titration curve, you can easily enough judge whether the acid is weak or strong. Note, that a strong acid will not present pH buffering as you begin and continue to approach the endpoint with titrant additions; and the equivalence point pH should be sudden and extremely close to 7.
Related Threads on Strong or weak acid?
  • Last Post
  • Last Post
29K
  • Last Post
9K
  • Last Post
62K
  • Last Post
  • Last Post
9K
