Structure Problem Continues
  • Thread starter Lancelot59
Lancelot59
643
I'm actually getting pretty frustrated with this now. It makes no sense.
I have this structure defined in detector.h
Code:
//This structure contains all raw sensor data
struct sensor_data
	//ADC Values For Each Sensor
	int ADC_LOuter;		//Outer Left Sensor
	int ADC_LInner;		//Inner Left Sensor
	int ADC_Centre;		//Centre Sensor
	int ADC_RInner;		//Inner Right Sensor
	int ADC_ROuter;		//Outer Right Sensor
	//Whether or not the sensor is on the track
	unsigned int Track_LOuter;		//Outer Left Sensor
	unsigned int Track_LInner;		//Inner Left Sensor
	unsigned int Track_Centre;		//Centre Sensor
	unsigned int Track_RInner;		//Inner Right Sensor
	unsigned int Track_ROuter;		//Outer Right Sensor
struct sensor_data Sensor;
and the compiler is complaining that it has multiple definitions
Code:
MPLINK 4.22, Linker
Copyright (c) 2008 Microchip Technology Inc.
Error - symbol 'Sensor' has multiple definitions.
Errors    : 1
This makes no sense. There is no mention of that structure anywhere else in the code. The individual values are only set to equal things of the same data type.
What does this error mean?
Answers and Replies
8,173
If there is no mention of that struct anywhere else in the code, why is it in your header file?
The line following the struct definition --
-- is creating an instance of that struct, named Sensor. It doesn't make much sense to me why that line of code is there, since the struct instance is uninitialized (i.e., filled with garbage values.
I think that if you take a close look at your code, you might find that the name Sensor is defined somewhere else, and that seems to be what the linker is complaining about.
Lancelot59
643
I went though everything and the only place that the word sensor is used other than in that struct definition is in my comments describing how it works.
Also, why doesn't it make sense for struct sensor_data Sensor; to be there? From my understanding you have to create an instance of the structure before you can use it.
What do you mean why is it in the header file? Are you not supposed to define and instantiate structures in headers?
8,173
I still believe that Sensor is declared somewhere else and you're missing it. The linker (not the compiler) is convinced that you are defining Sensor in two or more places. How about showing us your code?
If you truly believe that Sensor isn't defined anywhere else, then I ask again, why is it in your header file? If you program isn't using it, then there is no reason for the struct definition and struct instantiation to be there. Note that these are two different things. The struct definition is a template that defines how variables of this type should be laid out in memory. The compiler doesn't allocate any memory for a struct template definition. It does, however, for a struct variable declaration.
One thing you could do is comment out the whole struct definition and the struct variable declaration (the line struct sensor_data Sensor;).
That's true, but your are saying that you aren't using it. Also, you are creating an uninitialized struct variable instance in your header file, which means that you have a global struct variable, which is something D H talked about in your other thread on this struct.
When a struct is used, a header file normally contains only the struct template definition, not a struct variable declaration/definition.
Lancelot59
643
Well, there is a bunch of code, so I'll sort though it and paste the important bits.
The thing is that I need that structure to be accessable by a whole bunch of functions. Also, a bunch of these functions are defined in separate files. I guess I could include the templace in the system_config.h file and instantiate it in the main before the infinite loop starts. But for some reason I can't pass stuff by reference, it gives me a syntax error.
For example void(int& var) is invalid apparently.
8,173
The thing is that I need that structure to be accessable by a wide variety of functions, and for whatever reason when I try to pass stuff by reference it gives me a syntax error.
Include your main function and one of the functions that uses the struct.
void fn(int& var) is valid in C++, but not in C.
Lancelot59
643
Ah...this is a problem. If I pass it the structure will it be pointing to that structure directly, or will it just give it the information and not be able to edit it like in C++?
If that is the case then I need to figure out how to use pointers.
8,173
If you pass the struct by reference (using & in C++ or * in C), the function can modify what is referred to. If you pass the struct by value, the function is working with a copy of the original, so cannot modify the original.
Lancelot59
643
Right, so I need to figure out how to make pointers work.
If I understand this correctly, I can instantiate the structure, then create a pointer of the same structure type, and then set the address like so:
struct sensor_data Sensors;
struct sensor_data *SensorPoint;
SensorPoint = &Sensors
Then once I have that I can just pass that pointer around and have it access the original?
8,173
You should still take the line struct sensor_data Sensor; out of your header.
In the first line of your code above, you are creating an uninitialized struct variable. It will be filled with garbage values or zero values, depending on where in your code this line appears (i.e., depending on whether the struct variable is local to some function or global).
You can combine your second and third lines of code like so:
struct sensor_data *SensorPoint = &Sensors;
Here SensorPoint is declared and initialized with the address of the Sensors variable.
Lancelot59
643
Okay, I removed the structure from the detector header. Now the definition is above the main function, and the instantiation takes place in the main function just after the first initialization function is run.
I isolated the main function from everything else for this test:
Code:
struct sensor_data
//MAIN function performs initialization and runs the monitor function
void main(void)
	//initialize();	//Performs initialization
	struct sensor_data Sensor;		//Creates structure that holds all sensor data
	struct sensor_data *SensorPoint = &Sensor;
	printf("%c%c",0xFE,0x01);
	printf("INITIALIZATION  COMPLETE");
	//Two second delay
	Delay10KTCYx(200);
	Delay10KTCYx(200);
	Delay10KTCYx(200);
	Delay10KTCYx(200);
	Delay10KTCYx(200);
	Delay10KTCYx(200);
	Delay10KTCYx(200);
	Delay10KTCYx(200);
	printf("  PATHFINDING  ");
	//Repeatedly calls the monitor function
	while(1)
		//Calls the monitor function
		//OM NOM NOM NOM NOM
		//monitor();
So now all I need to do is pass the pointer into other functions, like so:
fn(SensorPoint)
and the prototype would be
fn(sensor_data SensorPoint)
and to access anything
SensorPoint.member?
8,173
Is one of the functions called in main going to initialize your global struct variable?
Inside one of the functions, you can access the struct in either of two ways:
SensorPoint -> member_name
or
*(SensorPoint).member_name
SensorPoint.member_name doesn't work because SensorPoint isn't a struct variable; it's a pointer, and pointers don't have struct fields.
Lancelot59
643
The main function will instantiate the structure. I'm getting a syntax error now though:
Code:
void main(void)
	[B]struct sensor_data Sensor;		[/B]//Creates structure that holds all sensor data
The error is on the bolded line. I'm guessed the error is actually in the initialize function somewhere, but it isn't.
8,173
What's the text of the error? Is it a compiler error or a linker error? Compiler errors usually tell you the line where the error occurs.
You're calling initialize() before creating the Sensor variable. IOW, you are apparently trying to initialize something before it actually exists.
The scope of the Sensor variable is within main. Other functions, including initialize(), aren't aware of Sensor.
If I understand what you're trying to do, you need to do things in this order:
Create your struct variable.
Initialize the struct variable.
Lancelot59
643
I moved the call down and it worked! Hooray for progress! :D
I'll clean up the other functions and see how it goes.
I'm passing the pointer like so:
prototype: fn(sensor_data SensorPoint)
call: fn(SensorPoint)
Lancelot59
643
Update:
Alrighty, it's working ok, but I'm having an issue passing the pointer.
In this set of code sensor_data is the name of the structure template, and S is the pointer.
Function definition
Code:
void monitor(struct sensor_data *S)
	forward();	//Move forward
Function prototype
Code:
void monitor(struct sensor_data *S);
and I get this:
Code:
monitor.c:40:Error [1109] type mismatch in redeclaration of 'monitor'
They're the exact same, so I'm lost as to where this is coming from. This textbook I have says that should work.
EDIT: I solved it, turns out I had the header included. That's probably what was giving me issues in some of the other sections.
Lancelot59
643
or
Now I'm getting an error when I try to write with that pointer.
First I got an error with a type mismatch in a redeclaration of the function prototype:
Code:
detector.h:14:Error [1109] type mismatch in redeclaration of 'ADC_ALL'
Code:
void ADC_ALL(struct sensor_data *SensorPnt);
and
Code:
//Performs An ADC Reading On All RLS Channels
//Reads left to right
	//Reads Left Outer Sensor
	SetChanADC(RLS_LOuter);
	ConvertADC();
	while(BusyADC());
	*SensorPnt.ADC_LOuter = ReadADC();
    //Reads Left Inner Sensor
	SetChanADC(RLS_LInner);
	ConvertADC();
	while(BusyADC());
    //Sensor.ADC_LInner = ReadADC();
    //Reads Centre Sensor
	SetChanADC(RLS_Centre);
	ConvertADC();
	while(BusyADC());
    //Sensor.ADC_Centre = ReadADC();
    //Reads Right Inner Sensor
	ConvertADC();
	while(BusyADC());
    //Sensor.ADC_RInner = ReadADC();
    //Reads Right Outer Sensor
	ConvertADC();
	while(BusyADC());
    //Sensor.ADC_ROuter = ReadADC();
I went though and there is nothing else with that name.
When I told it to go past that I got this error:
Code:
detector.c:62:Error [1207] tag 'sensor_data' is incomplete
detector.c:62:Error [1131] type mismatch in assignment
What I did was pass the pointer to the monitor() function, then it passes it through to the detector function. Do I need to make another pointer variable in monitor before I can pass it along? Or can I just continue with the current setup:
Code:
void monitor(struct sensor_data *SensorPnt)
	ADC_ALL(SensorPnt);
8,173
Is ADC_ALL declared in sensor.h? Names in all caps are usually constants, so it's not a good idea to name a function with all caps.
This line of code isn't doing what you think it is.
Code:
It calls ReadADC(), which does something and returns some value. (I have no idea what it does or what it returns.) On the left side of the assignment statement, it attempts to access the ADC_LOuter field of what it thinks is a struct, and then attempts to dereference what should be a pointer, but isn't.
As I said a few posts ago, there are two ways to dereference a pointer to get at a member of a struct being pointed to, and the way you did it was neither of them.
You can do this:
SensorPnt ->ADC_LOuter = ReadADC();
or you can do this:
(*SensorPnt).ADC_LOuter = ReadADC();
You can't do this:
In the first two, SensorPnt is dereferenced, which gives you access to the struct variable it's pointing to, and then you get access to the ADC_LOuter field of the struct variable.
The reason things happened the way they did is operator precedence in C. The struct member operator, . , has higher precedence that the pointer dereference operator, *.
This expression, *SensorPnt.ADC_LOuter, is exactly the same as if had been written as
*(SensorPnt.ADC_LOuter)
When you want a lower precedence operator to operate before a higher precedence operator, you use parentheses. In this case it would be (*SensorPnt).ADC_LOuter
For your last question, what does forward() do? You aren't passing any arguments to it, so it doesn't know about any local variables in the function that's calling it.
Lancelot59
643
Oh, I tried using (*SensorPnt) and I got an error, I'll try this again and see what I get.
ReadADC() is a function in the compiler the takes an ADC reading from the PIC's ADC port (which ever one is defined as active by the set channel function)
forward() is a function I defined, it just makes the robot go straight forward. I created a library of functions for basic movements: forward, reverse, spin, pivot, etc.
ADC_All is declared in detector.h
Lancelot59
643
Well, I fixed it, and still got the error when I commented out the function header:
Error with prototype:
Code:
Error [1109] type mismatch in redeclaration of 'ADC_All'
Error without prototype and fixed pointer:
Code:
Prototype
Code:
void ADC_All(struct sensor_data *SensorPnt);
Definition
Code:
	ConvertADC();
	while(BusyADC());
	ConvertADC();
	while(BusyADC());
	ConvertADC();
	while(BusyADC());
	ConvertADC();
	while(BusyADC());
	ConvertADC();
	while(BusyADC());
But my student version of the compiler expired, and it now omits the following:
* Not all optimizations will be supported. Namely, procedural
abstraction will not be supported.
* The PIC18 Extended mode (extended instruction set and indexed with
literal offset addressing) will not be supported.
Is that the reason why? Because when I make the arguments void it goes past that spot fine. :/
Also apparently monitor can't see the prototype for the detector functions even though I've included it, not can it see the prototypes for the movement functions like forward. :/
8,173
What type does ReadADC return?
The messages that the compiler is emitting might be part of your problems.
Lancelot59
643
It returns an int, so that's not the issue. I even made a random test variable and set it equal to one in it's place and that caused the same issue.
The problem is this I think
Code:
59:Error [1207] tag 'sensor_data' is incomplete
And according to the manual:
Code:
1207: tag '%s' is incomplete
An incomplete struct or union tag cannot be referenced by the member
access operators. Common causes include a misspelled structure tag
name in the symbol definition.
But you can see from the code that everything is spelled correctly.
Code:
	struct sensor_data SensorData;					//Creates structure that holds all sensor data
	struct sensor_data *SensorPnt = &SensorData;	//Creates a pointer for SensorData
I passed it to monitor like so:
Code:
monitor(SensorPnt);
and it passed to adc
Code:
	adc(SensorPnt);
I do get a warning in main.c
Code:
main.c:112:Warning [2054] suspicious pointer conversion
which apparently means that:
2054: suspicious pointer conversion
A pointer has been used as an integer or an integer has been used as a
pointer without an explicit cast.
where I pass monitor the pointer. I don't get it.
Lancelot59
643
I'm still getting this error:
what the crap is happening here?
Code:
struct sensordata SensorData;					//Creates structure that holds all sensor data
struct sensordata *SensorPnt = &SensorData;		//Creates a pointer for SensorData
Code:
struct sensordata
	//Times flags for each of the sensors
	int FLAG_LOuter;		//Outer Left Sensor
	int FLAG_LInner;		//Inner Left Sensor
	int FLAG_Centre;		//Centre Sensor
	int FLAG_RInner;		//Inner Right Sensor
	int FLAG_ROuter;		//Outer Right Sensor
everything is clean, so what the hell can it possibly be complaining about?
8,173
You have struct sensordata in one place, and struct sensor_data elsewhere. That's a big problem.
Lancelot59
643
I cleared all that out, and I'm still getting the error.
I'm having to comment out the prototype for adc which I now call Scan_All() because it gives me another error.
detector.h:14:Error [1109] type mismatch in redeclaration of 'Scan_All'
which again I don't see the cause of because the prototype is:
void Scan_All(struct sensor_data *);
and the head of the definition is:
void Scan_All(struct SensDat *SensorPnt)
8,173
You are continuing to make the same mistake. The name of the struct template (the tag) is sensor_data. The compiler has a struct template for sensor_data, but it doesn't have one for SensDat. You can have a number of different struct variables based on one template, but if there's only one template you have to use that template name when you create struct variables of that type.
I would advise you to get a reference on C to help you understand the basics of how this language should be used. A couple that come to mind are The C Programming Language, by Kernighan and Ritchie, another whose name I forget by Harbison and Steele. There are also several by Herb Schildt. A few hours invested in reading these books would save you many hours of futile debugging attempts.
Lancelot59
643
Sorry, I mixed up the code. I fixed that and forgot to edit the post.
I understand that about the structure, and before I started posting here I read through several sections that covered this. I sat down again and read it before taking this particular attempt.
Lets take a look at it on a smaller setup then, just passing to one function.
Say I have main with the same old setup:
Code:
struct sensor_Data
void main(void)
	struct sensor_Data *SensorData;						//Creates structure that holds all sensor data
	struct sensor_Data *SensorPnt = &SensorData;		//Creates a pointer for SensorData
	while(1)
		monitor(&SensorPnt);
Now say I just want to pass it to monitor, instead of a whole host of functions down below. The template is sensor_Data, and the name is SensorData. The pointer is also of the same type and initialized to the address of SensorData after it is created.
Now I have the revised monitor:
Monitor expects a pointer of the sensor_Data type, and it will be seen in the function as "Pnt".
Code:
void monitor(struct sensor_Data *);
Code:
void monitor(struct sensor_Data *Pnt)
	int i;
	for(i=0;i<1024;i++)
		Pnt->ADC_LOuter = i;
                (*Pnt).ADC_LInner = i;
According to the books I have here, and your own explanations this is valid, however I get these three errors:
Code:
monitor.c:46:Error [1207] tag 'sensor_Data' is incomplete
monitor.c:46:Error [1131] type mismatch in assignment
monitor.c:47:Error [1207] tag 'sensor_Data' is incomplete
monitor.c:47:Error [1131] type mismatch in assignment
I don't really see why it thinks the tag is incomplete, nor why it thinks the value is different.
If I can't get these pointers working I'm going to have to revert a a cheap global variable setup, I know it's bad but I'm quickly running out of time I have to make this thing work.
EDIT: You're gonna facepalm when you hear this, but I somehow removed the include statement for main.c. It solved most of my problems.
Except now I get this:
The error is found in the function head.
Code:
here are the head and prototype:
I ran a search and monitor isn't defined anywhere else...
8,173
I don't see anything wrong with the header and prototype of monitor. What could be going on is that monitor is defined differently in some other header file you're including. Look in your documentation for your compiler and see if it mentions a function or variable of some type with this name. If that's the case, change the name of your function.
I noticed something else that looks like a bug:
Code:
void main(void)
In the first line, SensorData is declared to be a pointer to a sensor_Data struct variable. SensorData is not a good name for a pointer, since it doesn't convey in its name that it is a pointer to something. Better names would be ptr_sensor_Data or sensor_Data_ptr or the like.
In the second line, you are initializing SensorPnt with the address of a pointer variable. In effect SensorPnt is a pointer to a pointer to a struct variable. There are legitimate reasons for doing things like this, but I don't believe that you really want to do this.
Lancelot59
643
Wait, what?
Are you saying that I've been calling two pointers, one of which was SensorData this whole time!?
...FUUUUUUUUUUUUCCCC--
Okay, so to fix that, I just make it this instead?
Line 1 makes the structure?
Line 2 makes the pointer?
Code:
void main(void)
	struct sensor_Data SensorData;
8,173
Yes, line 1 creates an instance of your struct type, and line 2 creates a pointer that is initialized with the address of the struct variable.
  • #31
Lancelot59
643
Alright then, so that's fixed. I'll try compiling it soon. I went though the function listing and there is no monitor function defined. So I'm not too sure where this is coming from.
  • #32
36,191
8,173
Change the name of your monitor function.
Suggested for: Structure Problem Continues
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
