Stuck on an integral
  • Thread starter duelle
1. The problem
Find the definite integral.
[tex]\int \frac {t^2 - 3}{-t^3 + 9t + 1} dt[/tex]
2. The attempt at a solution
The answer is the book made it seem like the rule [itex] \int \frac {du}{u} = ln|u| + C [/itex] was used. Here's what I got:
[tex]u = -t^3 + 9t + 1[/tex]
[tex]du = -3t^2 + 9\;dt[/tex]
[tex]-\frac{1}{3}du = t^2 + 9\;dt[/tex]
Obviously this won't work out, so is there something I'm overlooking that anyone can point out?
Answers and Replies
yes that rule is used, but when you take du, you're entire quantity needs to be multiplied by dt.
the last line of your calculation is wrong.
notice that it should be:
[tex]-\frac{1}{3}du=(t^2-3)dt[/tex]
you forgot changing the dt.
you've got the right substitution. By rearranging your du formula for dt you'll get:
dt = -du/(3(t^2-3))
and it will cancel out leaving you with the simple integral
Wow, I feel dumb. Thanks for pointing that out, though.
Related Threads on Stuck on an integral
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
