Homework Help: Stuck on Lorentz Transformations
  1. Dec 12, 2015 #1
    Hello I need some advice on how to figure out Part F of the following problem. I was able to find the correct answer but in a very illogical way. I was wondering if I could get some help understanding the lorentz transformations necessary. Here is the full problem, I have parts a-e solved and put the answer for f.
    A rocket that has a proper length of 746 m is moving to the right at a speed of 0.882c. It has two clocks—one in the nose and one in the tail—that have been synchronized in the frame of the rocket. A clock on the ground and the clock in the nose of the rocket both read zero as they pass by each other.
    (a) At the instant the clock on the ground reads zero, what does the clock in the tail of the rocket read according to observers on the ground? A: 2.19 µs
    (b) When the clock in the tail of the rocket passes the clock on the ground, what does the clock in the tail read according to observers on the ground? A: 2.82 µs
    (c) When the clock in the tail of the rocket passes the clock on the ground, what does the clock in the nose read according to observers on the ground? A: .63 µs
    (d) When the clock in the tail of the rocket passes the clock on the ground, what does the clock in the nose read according to observers on the rocket? A: 2.82 µs
    (e) At the instant the clock in the nose of the rocket reads 1.00h, a light signal is sent from the nose of the rocket to an observer standing by the clock on the ground. What does the clock on the ground read when the observer on the ground receives the signal? A: 3.99 h
    (f) When the observer on the ground receives the signal, he immediately sends a return signal to the nose of the rocket. What is the reading of the clock in the nose of the rocket when that signal is received at the nose of the rocket? A: 18.3 h
    2. Relevant equations
    x = ɣ(x' + vt')
    t = ɣ(t' + (vx')/c^2)
    ɣ = 1/sqrt(1-(v^2/c^2))
    3. The attempt at a solution
    I have the earth as farm S and the ship as frame S'.
    I know that the signal is received at earth at t = 3.99h from part e. I then know due to the speed that the ship is a distance of 3.52 c * h away so light would take another 3.52h to reach that point. I am unable to figure out what to transform or how to calculate the last section where the light catches the ship. Any help would be very appreciated.
  3. Dec 12, 2015 #2
    Orodruin
    Staff Emeritus
    2017 Award
    But during those 3.52 h, the ship moves further away from the Earth and so the signal does not take 3.52 h to reach the ship in the Earth frame.
    I suggest you transform the event of the Earth signal being sent to the rocket's frame. This will make the problem much easier to solve.
  4. Dec 12, 2015 #3
    In the rocket frame of reference, what is the time t' and location x' when, in the earth frame of reference, x = 0 and t = 3.99 hr? How long does it take for a signal to travel from this x' location to x' = 0 (the nose of the rocket)?
  5. Dec 12, 2015 #4
    t' = gamma (t - vx/c^2)
    t' = 2.12 (3.99 - 0)
    t' = 8.46 hrs
    x' = gamma (x - vt)
    x' = 2.12 (0 - .882c * 3.99)
    x' = -7.46 c*hr
    So time to travel from x' = -7.46ch to x' = 0 at a signal speed of c = 7.46 hrs.
    So now I have the time it takes the signal to reach the nose of the rocket in the frame of the rocket which converted to the frame of the earth is:
    t = gamma (t' + vx'/c^2)
    I'm slightly confused on which values to use at this point.
    t = 2.12 (7.46 + (c)(-7.46ch)/c^2)
    Which is getting me 0.
    Do I use t' = 8.46 found earlier or am I setting this up incorrectly.
  6. Dec 12, 2015 #5
    Once you have determined the location and time of the signal in the rocket frame of reference, you can forget about the earth frame of reference and focus entirely on the rocket frame. As you said, in the rocket frame, the signal was sent at t'=8.46 hr, and it then takes Δt'=7.46 hr for the signal to reach the nose of the rocket. So, in the rocket frame of reference, at what time does the signal reach the nose?
  7. Dec 12, 2015 #6
    So if it's sent at t' = 8.46 and takes 7.46 hours to reach the nose of the rocket. In the rocket frame it will reach the rocket at t'=15.92 hrs. Which isn't giving me the correct answer of 18.3 hrs which is why I felt the need to do some form of transformation. Is there something I should do with the 15.92 beyond that answer?
  8. Dec 12, 2015 #7
    Orodruin
    Staff Emeritus
    2017 Award
    I suggest you keep all of your digits when doing computations, or at least round the answer to a number you can trust given the number of digits you used throughout your computation.
    By symmetry, the ratio between your answer in (e) and 1 h should be the same as the ratio between your answer in (f) and that in (e). It is therefore impossible that both given answers are correct.
  9. Dec 12, 2015 #8
    I get 15.9 hr also. I am unable to duplicate the 18.3
    Chet
  10. Dec 14, 2015 #9
    The answers 3.99 for (e) and 15.92 for (f) satisfy Orodruin's criterion in post #7. In particular, 3.992=15.92. So they must be right.
    Chet
Have something to add?
Draft saved Draft deleted
