Stuck-Resistivity problem
  • Thread starter kriegera
kriegera
74
A transmission line is made of aluminum wire 1 inch in diameter. What is the resistance of 20 miles of this wire?
Resistance varies directly with the length of a wire and inversely with its cross-sectional area.
Resistivity of aluminum = 2.8 x 10-8
R=pl/A
Where l=32,186.88 meters
Find cross-sectional area.
R= 2.8 x 10-8 (31,186.88)/A =
I'm stuck trying to find the cross-sectional area, A.
Also, the answer has to be in the same units as the problem, so does that mean I have to convert to inches and miles? The answer should be in ohms correct?
Answers and Replies
rock.freak667
6,223
31
The wire is like a long shaft or a long cylinder, so the cross-sectional area is?
Also, you need to convert everything to same set of units. What is the resistivity measured in?
kriegera
74
The cross-sectional area would be the diamter then? Converted to meters, we get
R= 2.8 x 10-8 (32,186.88)/0.0254 = .0354816 ohm-metres
correct?
rock.freak667
6,223
31
No, the cross-section of the wire is just a circle with diameter 'd'. So the area of a circle is ?
kriegera
74
SO - Cross-Sectional Area= = Area: (pi)(.0127) ² = 5.067E-4
R= 2.8 x 10-8 (32,186.88)/ 5.067E-4 = 1.79 ohm-metres
rock.freak667
6,223
31
Yes that should be correct now.
Suggested for: Stuck-Resistivity problem
  • Last Post
