Stuck with a projectile question
  1. Dec 14, 2013 #1
    Question;
    A rocket launched at 70 degrees to the horizontal has constant net acceleration of 8m/s^2 along its path for 6.5 seconds and then is in free fall!
    What is the rockets maximum height?
    Ps answer is 281m I couldn't help but look lol
    Solution attempt:
    From the net acceleration I got the velocity as simply the acceleration multiplied by the time
    And from that tried to use kinematic equations but got wrong answers every time! This keeps happening with projectile questions!! Frustrating!!!
    I think my error could be because net acceleration = change in velocity/ time
    But I'm not sure!!
  3. Dec 14, 2013 #2
    ehild
    Can you show what you did, please...
    ehild
  4. Dec 14, 2013 #3
    Concentrate on only the vertical component of acceleration and displacement etc.
    You have a resultant acceleration in a given direction, find the acceleration in the direction you need
  5. Dec 14, 2013 #4
    So I take the component in the vertical direction?
    8sin70= 7.5m/s^2
  6. Dec 14, 2013 #5
    Yeah, from there you should be able to get your answer of 281m (which is correct, books can be prone to errors sometimes though)
    Remember in free fall that the acceleration would be -9.81ms^2
  7. Dec 14, 2013 #6
    haruspex
    There's something a bit fishy about the given information. How will the rocket have constant acceleration 'along its path'? If we take the thrust as a vector at 70 degrees to the horizontal, then add gravity, we'll not get an acceleration that is along its path. Is it possible that it means only that the component of its acceleration along its path is 8m/s^2?
  8. Dec 15, 2013 #7
    ehild
    If you try to read the mind of the problem writer, the net acceleration should mean a vector that makes 70 degrees with the horizontal and of magnitude 8 m/s2. That acceleration is the resultant of gravity and that of the thrust.
    ehild
  9. Dec 15, 2013 #8
    haruspex
    Yes, I suppose it could have fins such that although the engine thrust is along its path it can derive a component to cancel gravity. I still feel it's not entirely unambiguous.
Have something to add?
Draft saved Draft deleted
Similar Discussions: Stuck with a projectile question
Loading...
