Homework Help: Stuck with integration
  1. Apr 11, 2005 #1
    [tex]\int_a^b f(x)dx = a+2b[/tex]
    [tex]\int_a^b (f(x)+5)dx =?[/tex]
    [tex]\int_a^b (f(x)+5)dx =\int_a^b f(x)dx+\int_a^b 5dx[/tex]
    [tex]a+2b+\int_a^b 5dx[/tex]
    I'm stuck, what should be my next step?
  3. Apr 11, 2005 #2
    HallsofIvy
    Are you serious? You can't integrate [tex]\int_a^b5dx[/tex]?
    Isn't that the same as [tex]5\int_a^b dx= 5(b-a)[/tex]?
    Isn't that about the first thing you learned in integration?
  4. Apr 11, 2005 #3
    hehe, thanks
    what's the rule for [tex]\int e^x[/tex]?
    is it [tex] e^x \int x[/tex]?
  5. Apr 11, 2005 #4
    dextercioby
    Why?It's the exponential.Integration just adds a constant...Don't forget the differential of "x".
    Daniel.
  6. Apr 11, 2005 #5
    [tex]\int e^x[/tex] = [tex]\int e^x dx[/tex] ?
  7. Apr 11, 2005 #6
    dextercioby
    No,no,the first notation is incorrect.It should always be
    [tex] \int \ \mbox{function} \cdot \mbox{element of integration} [/tex]
    Daniel.
  8. Apr 11, 2005 #7
    so if a question was [tex]\int e^{\frac{x}{2}} dx = e^{\frac{x}{2}} \int \frac{x}{2} dt[/tex]
  9. Apr 11, 2005 #8
    HallsofIvy
    [tex]\int e^x dx= e^x+ C[/tex]
    because [tex]\frac{d e^x}{dx}= e^x[/tex], of course.
  10. Apr 11, 2005 #9
    dextercioby
    No,if course not.U need to make a substitution
    [tex] \frac{x}{2}=u [/tex]
    Daniel.
    EDIT:BTW,knowledge of integration techniques assumed knowledge of differentiation methodes.
  11. Apr 11, 2005 #10
    [tex]\int e^{\frac{x}{2}} dx[/tex]
    [tex]u=x/2[/tex]
    [tex]du=1/2dx[/tex]
    [tex]\int e^{u} 2du[/tex]
    [tex]=2e^{\frac{x}{2}} [/tex]
  12. Apr 11, 2005 #11
    HallsofIvy
    Let u= x/2. Then 2u= x so 2du= dx.
    [tex]\int e^{\frac{x}{2}}dx[/tex] becomes [tex]2\int e^u du= 2e^u+ C= 2e^{\frac{x}{2}}+ C[/tex]
    Surely you've learned simple substitutions.
    [tex]e^x\int \frac{x}{2}dt[/tex], on the other hand, is [tex]e^x(\frac{x^2}{4}+ C)[/tex].
  13. Apr 11, 2005 #12
    dextercioby
    That's right up to a constant,which should never be forgotten when computing indefinite integrals.
    Daniel.
  14. Apr 11, 2005 #13
    is [tex]cos^2(x)=cos(x)cos(x)[/tex]
    so..
    [tex]\frac{d}{dx}cos^2(x)=-2sin(x)cos(x)[/tex]
  15. Apr 11, 2005 #14
    dextercioby
    Yeah,why?U could apply the chain rule as well.
    Daniel.
  16. Apr 11, 2005 #15
    HallsofIvy
    Yes, by golly!
    (I think we are posting a cross purposes now!)
  17. Apr 11, 2005 #16
    so if e is raised to any exponet that is not x, then I must use a subsitution when integrating?
  18. Apr 11, 2005 #17
    dextercioby
    Yes.Always.Make that depends from case to case.Usually the antiderivatives of exponentials of "weird" arguments are not expressible in terms of "elementary functions".Simples example
    [tex] \int e^{-x^{2}} \ dx [/tex]
    Daniel.
  19. Apr 12, 2005 #18
    Just out of curiousity, when I did that particular integral on Mathematica's Online Integrator, I got:
    [tex] \int e^{-x^{2}} \ dx = \frac{1}{2}\sqrt{\pi} ERF[x] + C[/tex]
    Can someone tell me what Erf is?
  20. Apr 12, 2005 #19
    dextercioby
    Sure
    [tex] \mbox{erf} \ (x)=:\frac{2}{\sqrt{\pi}} \int_{0}^{x} e^{-t^{2}} \ dt [/tex]
    Daniel.
  21. Apr 12, 2005 #20
    Well, then that makes perfect sense. Is that something that is standardly used in Calculus? The constant seems to be random.
