Stunt people can fall from great heights
  • Thread starter RachelSSS
  • Tags
    Fall
In summary, momentum is conserved in collisions when there is no net external force on a system. In highly inelastic collisions, kinetic energy is not conserved and is instead converted into other forms of energy. A desirable situation for a highly inelastic collision is in a car crash, where the change in momentum is reduced and the impulsive force is lessened, resulting in less damage to passengers. In motion pictures, stunt people can land safely on giant airbags due to the longer time taken for the change in momentum to occur, resulting in a smaller impulsive force and less injury.
RachelSSS
Explain how momentum can be conserved in a collision when kinetic energy is not? Describe a situation in which it is desirable to have a highly inelastic collision. Explain why in this case. In motion pictures, stunt people can fall from great heights and land safely on giant airbags. Using the principles of momentum and impulse, explain how this is possible.
I have no idea. ANy ideas? please and thank you :)
You have to give some ideas of your own, before we can give ours, because this is a homework help forum, not HW do forum.
Well, i think that kinetic energie can't be destroy, but in an inelastic collision, the kinetic energy turns into different kinds of energy like internal energy.
i thoguht a car crash would be a good explain for a inelastic collision. Becasue they crumple up and stick together. Which happens in an inelastic colisn.
That is correct. But what happened to the momentum conservation?
well, I am not totally sure, but i think momentum is alwasy conserved, becasue it can't leave the objects the are in collision.
Have you been taught the mathematics of momentun conservation and impulse etc.? From which level are you expected to give the answers?
like... p = mv. impulse is the change in momentum so p=mv2-mv1. Grade 12 physics
Try to write the answer in your own way.
In a collision, momentum is conserved becasue the lose of one object is the gain of another object and vice versa. But kinetic energie is not conserved, but change into a differnt type of energie (thermal, internal, etc.)
The way you should write it is: when there is no net external force on a system, the total linear momentum of the system is conserved.
What you have said is correct about the momentum. However, the KE may or may not be conserved. In perfectly elastic collisions, the KE is conserved.
You have chosen the example of a car crash for this. While the incident itself is highly undesirable, why do you feel it is better for a crash to be inelastic rather than elastic?
Ok, well... waht about a hammer hitting a nail. An inelastic collision would transfer the energy into hitting the nail straight in
Actually, no. The nail will suffer from more change of momentum if the hammer bounces back. Does this give you a clue for the car crash scenario?
how is a car crash desirable tho. people will just get hurt and/or die. Well if the car crash is highly inelastic, would the cars would just bounce off each other kinda?, and if it was elastic they would get smashed even more
The car crash was your idea. But if at all there is a crash between two cars or a car and a fixed object, it's better if it's inelastic. Suppose that the speed of a car is v, and the collision is perfectly elastic. If the car bounces back with speed v, that means that the total change in momentum is (final – initial) = mv-(-mv) = 2mv. But if the car does not bounce back, the change in momentum is simply mv - 0 = mv.
Also, if the time of impact is more, the impulsive force is reduced in magnitude, reducing damage to passengers. That's why cars have crumple zones.
Now it’s your turn. You have enough clues now.
Well for this one i was thinking that when the actor falls, he has a lot of momentum. so i wasnt sure how he was goign to stop and actually be safe. but went hits the air bag, there's an impulse with changes his momentum to 0?
You've almost got it. You're right: he has a lot of momentum, and then he has none, so there was a big change in momentum. On the other hand, what does your intuition tell you about landing on a hard sidewalk as opposed to landing on a nice big fluffy air bag? Which hurts more?
Remember, it takes a force to change momentum, and a big force to your face will hurt. How is force related to change in momentum? If change in momentum is fixed (the stunt guy is going to lose the same amount of momentum, no matter what he lands on), what else can vary in order to get a smaller force?
(To RachelSSS)
If he hits concrete, that would also change his momnetum to zero, in an undesirable way. So, that can't be the answer. Read post #14 again, and think what's the difference between hitting a hard surface and an airbag.
when your falling with a lot of momentum, you need a lot of force to stop you, the only forces acting on him would be the normal force and gravtity. The force of the air pushing him up after he hits the air bag.
But both the times, that is, when he is hitting a hard surface or an airbag, the force acting upward stops him. What is the difference in the two cases?
air is softer then concrete? I don't know. the airbag would the difference casue he'll bounce and not land on rock hard concrete
Yes, it's softer. That means that the time taken to reduce the momentum to zero is more in the case of airbag. Change in momentum = F*t, and since the change in momentum is the same in both cases, F is less in the case of the air bag because t is more.
so I am done that's it! the end! omg thanksssssssssssssssssssssss :):):):) oxoxoxox. 1 of 11 down. hahah thanks
1. How do stunt people prepare for falls from great heights?
Stunt people undergo extensive training and practice to prepare for falls from great heights. This includes learning proper techniques for safely landing, as well as physical conditioning to strengthen their bodies.
2. What safety measures are in place for stunt people when performing high falls?
Stunt coordinators and safety experts carefully plan and supervise high falls to ensure the safety of the stunt person. This may include using safety harnesses, landing pads, and other equipment to minimize the risk of injury.
3. Can stunt people really survive falls from great heights?
Yes, with proper training, equipment, and safety measures in place, stunt people can safely perform falls from great heights. However, there is always a risk involved and accidents can happen.
4. How do stunt people protect their bodies during high falls?
Stunt people often wear specialized padding and protective gear to help cushion their bodies during high falls. They may also use techniques such as rolling and controlled landings to distribute the impact of the fall.
5. Are there any risks or dangers associated with performing falls from great heights?
Yes, falls from great heights can be dangerous and even life-threatening if proper safety measures are not followed. Stunt people must undergo extensive training and work closely with safety experts to minimize the risks involved.
