Homework Help: Stupid Mathematics Issue
  1. May 9, 2010 #1
    Okay I've basically solved this problem... but I need some clarification.
    The problem is "The acceleration of an object is given as a function of its position in feet by a=2*s^2 ft/s^2. When s=0, it's veloctiy is 1 ft/s. What is the velocity of the object when s=2 ft?
    2. Relevant equations
    So since a=2*s^2, we can say dv/dt=2*s^2, and dv/dt=dv/ds*ds/dt=dv/ds*v
    3. The attempt at a solution
    Well, since acceleration is dv/ds*v, Int(v*dv)=Int(2*s^2*ds)
    So after integration, v^2/2=2/3*s^3.
    So upon solving for v, v^2=4/3*s^3, and therefore v=sqrt(4/3*s^3). With the initial condition when s=0, v=1, v=sqrt(4/3*s^3)+1 is what I get.
    This is wrong though. The correct answer to the problem is 3.42 ft/s, which I can get when v=sqrt(4/3*s^3+1), in other words, just including the 1 in the square root. I know I'm likely doing something really stupid...
    All I can figure is that like v^2/2=2/3*s^3+c... where c=1, only trouble is I don't think that's a true statement.
    So anyway... sorry for excrutiating detail, I just CANNOT figure out where I'm going wrong here.
    Thanks in advance. :)
  3. May 9, 2010 #2
    Ok. I think I'm over thinking this. v^2/2=2/3*s^3+c, so v^2=4/3*s^3+2c, and then v(s)=sqrt(4/3*s^3+2c), and since v(0)=1, sqrt(2c)=1, therefore 2c must=1. Is that the right way to think about this?
    Again sorry, I know these are really easy concepts we're dealing with here. Just wanna make sure I understand the algorithm to solve these simple diff eq's in dynamics situations.
  4. May 9, 2010 #3
    Dick
    v^2/2=2/3*s^3+c is figuring it correctly. You add the constant when you integrate. You don't add the constant after you've solved for v.
