XodoX
- 203
How do I show that the additive inverse, or negative, of an even number is an even number ( direct proof) ?
I have no idea. Anybody?
The proof involves using the definition of even numbers, which states that an even number can be divided by 2 without a remainder. We can show that the additive inverse of an even number can also be divided by 2 without a remainder, making it even.
Sure, let's take the even number 8. Its additive inverse is -8. When we divide -8 by 2, we get -4, which is an integer. This proves that the additive inverse of 8 is also even.
This proof is based on the property of additive inverses, which states that the sum of a number and its additive inverse is always equal to 0. In other words, for an even number n, n + (-n) = 0. Since 0 is an even number, this shows that the additive inverse of an even number is also even.
Yes, there is. The proof for odd numbers is based on the same concept, but using the definition of odd numbers. An odd number cannot be divided by 2 without a remainder, but when we add its additive inverse, the result can be divided by 2 without a remainder, making it an even number.
This proof is important because it helps us understand the relationship between even and odd numbers and how they behave under addition. It also shows that the properties of addition hold true for all types of numbers, including even and odd numbers. This proof is also a fundamental concept in higher level math and is used to prove more complex theories and theorems.
