tyrannosaurus
- 37
Let H be a subgroup of G.
Prove Z(G) intersect H is contained in Z(H),
use this result to verify that Z(G) intersect H is a normal subgroup of H.
Given an example where Z(G) intersect H is a proper subgroup of Z(H).
Z(G)= the center of G (x is an element of G |xa=ax for all a that is an element of G)
a. wts Z(G) intersect H is contained in Z(H)
So Z(G)=a is an element of G|ax=xa for all x that is an element of G. So Z(G) intersect H = a is an element of H|ax=xa for all x that is an element of G. Since an element a of Z(G) intersect H is in H and commutes with all of G, then it obviously commutes with all of H since H is a subgroup of G. Thus Z(G) intersect H is contained in H.
b. LTS that Z(G) intersect H is a subgroup of H.
Obviously Z(G) intersect H is contained within H as shown above.
Since the identity e is always in Z(G) and in H (since H is a subgroup of G), then Z(G) intersect H is nonempty. Let a,b be elements of Z(G) intersect H. Then ab=ba by defintion of Z(G) intersect H. Let a(b^-1) be an element of Z(G) intersect H.
Then a(b^-1)x=(b^-1)ax (since ab=ba implies (b^-1) = (a^-1)(b^-1)a.
Thus, by the 1-step subgroup test, Z(G) intersect H is a subgroup of H.
Since Z(G) intersect H = a is an element of H|ax=xa for all x that is an element of G,
then Z(G) intersect H, then the element a obviously commutes with everything in H if it commutes with everything in G. Thus Z(G) intersect H is an abelain subgroup of H and is normal.
3. My example is to consider D4 with H being <R90>. Then Z(G) intersect H= {R0, R180} which is a proper subgroup of Z(H) (Z(H)=<R90> which is of order 4).
Is what I did proving all of this check or not. I am unsure about proving containments and subgroup tests. Thanks for any help
