- #36
- 41,369
- 9,853
I'm puzzled there's been no response to my post (#31).
Isn't it the answer to the originally posed question? Do I need to explain more?
haruspex said:I'm puzzled there's been no response to my post (#31).
SeventhSigma said:not so much. I am trying to use a smaller set of S to see if I can count them properly. I am not sure that approach works because it's easier to count the extremities than it is to count the nitty gritty stuff towards the center of S where stuff gets messier
The original statement is this:ClifDavis said:For N=5 you calculate an answer of 9 subsets. But the subsets that fit the criteria are:
{1,2,3,4} 1+2+3+4=13>5
{2,3,4} 2+3+4=9>5
{1,3,4} 1+3+4=8>5
{3,4} 3+4=7>5
{1,2,4} 1+2+4=7>5
{2,4} 2+4=6>5
{1,2,3} 1+2+3=6>5
By my count that makes 7. If you could cough up another two, that would be interesting.
Note: highest number in the subset (not necessarily N).If I have a set of numbers from 1 to N, I want to know how to count sets such that the highest number in the set is smaller than the sum of the rest of the subset.
Necessarily, no subset of 1 or 2 elements can be valid.A valid subset is one where the largest element of the subset is less than the sum of the rest of the subset.
As I said, I believe ClifDavis' interpretation ("APN(N)", where a(N) is the highest in the set) is readily mapped to what you intended ("AP(N)") according to: AP(N+1) = AP(N) + APN(N+1). I.e. AP(N) = sum APN(1) to APN(N).SeventhSigma said:ClifDavis I think we may be talking about different problems. ... It's looking at a subset and checking the sum of inner elements against the highest element of that subset.
Quite so - at #31 I was answering the problem as originally posted. I came into the thread just at the point where you added the explanation about a(n) and posted my input without reading that update.haruspex: Those solutions aren't right either because your subsets include numbers (namely 5 in this case) that aren't in S.
Sorry, you've lost me. Which post is that in? If you mean post #37, that's where ClifD was saying I had the wrong answer to your original question (1, 2... n, rather than a(1), ... a(n)).SeventhSigma said:I don't think so, because in his earlier analysis he compares subset sums to 5, which is not a valid comparison. You need to compare the highest number of the subset against the sum of the rest of the subset
c(1) = 0
c(2) = 1
c(3) = 3
c(4) = 2^(3) - 1 + 2^(1)
c(5) = 2^(4) - 1 + 2^(2) + 1
c(6) = 2^(5) - 1 + 2^(3) + 3 + 1
c(7) = 2^(6) - 1 + 2^(4) + 2^(3) - 1 + 2^(1) + 3
c(8) = 2^(7) - 1 + 2^(5) + 2^(4) - 1 + 2^(2) + 1 + 2^(3) - 1 + 2^(1)
c(9) = 2^(8) - 1 + 2^(6) + 2^(5) - 1 + 2^(3) + 3 + 1 + 2^(4) - 1 + 2^(2) + 1 + 1
c(10) = 2^(9) - 1 + 2^(7) + 2^(6) - 1 + 2^(4) + 2^(3) - 1 + 2^(1) + 3 + 2^(5) - 1 + 2^(3) + 3 + 1 + 3
d(1) = 0
d(2) = 0
d(3) = 1
d(4) = 3
d(5) = 2^(3) - 1 + 2^(1)
d(6) = 2^(4) - 1 + 2^(2) + 1 + 1
d(7) = 2^(5) - 1 + 2^(3) + 3 + 1 + 3
haruspex said:Fwiw, I had a go at this simpler problem:
Sn = {A(1), .. , A(n)}, where the A(n) satisfy the recurrence relation A(n) = A(n-1) + A(n-3), etc.
How many subsets of Sn sum to A(n) exactly?
haruspex said:I can't even solve that yet. The problem is that some such subsets cannot be obtained by repeated application of the recurrence relation to break down the target sum. E.g. A(1)+A(2) = A(3).
