Subsets and Power Set
  • Thread starter Agent M27
Agent M27
171
I am currently covering Set Theory from the book, A Transition to Abstract Mathematics (Douglas Smith) and have a question about subsets and an implication. The statement reads as follows:
If B is a subset of A, then {B} is an element of the Power Set A.
I choose this to be true. By definition the Power Set A is comprised of all subsets of A. Given the first condition that B is a subset of A I can't really see how this is false, which the book gives as the correct answer. Does it have something to do with the braces around B? The way I interpreted the statement is: If B is a subset of A, then the set B is an element of the Power Set A. I know, for example, that when x is an element of A this does not automatically imply it is also an element of the Power Set A, this is one of the cases from which the confusion arises. Thanks in advance.
Joe
Answers and Replies
disregardthat
34
P(A) is the set of all subsets of A. B is a subset of A, so if {B} is an element of the power set of A, then {B} must be a subset of A. This is easily seen to be false in general. Pick e.g. A = empty set, then B = empty set is a subset of A. But the power set of A is {empty set}, which does not contain {B} = {the empty set} as an element.
But more interestingly, can it be true for any set A? Assume such an A exists.
A is a subset of A, so {A} is an element of P(A). But then {A} must be a subset A, so A is an element of A. This violates the axiom of regularity, so it cannot be true in ZFC.
Agent M27
171
Thanks a lot Jarle, the example of A= Empty Set is just what I needed to see the justification. Take care.
Joe
HallsofIvy
43,021
970
That statement,as written, is false. What is true is that if B is a subset of A, then B (not {B} which means the set containing a single member, B) is a member of the power set of P.
Yes. "B" is not the same as "{B}".
As I said before, {B} is the set that has the set B as its only member.
That's the same confusion in reverse! Suppose A= {1, 2, 3, 4}. Then "2" is a member of A but certainly not a subset of A (it is not a set at all- it is a number) and so not a member of the power set of A. B= {2} is a subset of A (it is the set whose only member is the number "2") and so a member of the power set of A. {B}, in that case, would be the set {{2}}, the set whose only member is the set whose only member is "2". Since B= {2} is not itself a member of A, it is {B}= {{2}} is NOT a member of the power set of A.
Thanks in advance.
Joe
Suggested for: Subsets and Power Set
  • Last Post
  • Last Post
  • Last Post
  • Last Post
MHB Set proof
  • Last Post
  • Last Post
  • Last Post
