Substitution in a differential equation, independent variable
In summary: Now you can see the pattern and you can use the integrating factor method. The integrating factor is the same one that you use in the standard method for a linear first order differential equation. I.e. the factor which makes the left side into a derivative of the product of that factor and the left side.In summary, the conversation discusses the substitution of ##z=\frac{1}{y}## in the differential equation $$y'=-\frac{1}{10}y+(cos t)y^2$$ to simplify the problem. It is noted that ##z(t)=\frac{1}{y(t)}## and the roles of t and y as the independent and dependent variables, respectively. The chain rule
fiksx
77
when doing substitute for ##z=\frac{1}{y}##
I understand this is ##z(t)=\frac{1}{y(t)}##
I know t is independent variable and y is dependent variable
but I want to know what is z role here, is it change the dependent variable?
when ##y(t)=\frac{1}{z(t)}##
then
I saw in book it is written ##y'=\frac{-z'}{z^2}##, is this means ##y(t)'=\frac{dz}{dy}\frac{dy}{dt}##?
is the relation is ##z(y(t))##? can someone explain the implicit differentiation in this expression? and what is dependent and independent variable here? thanks!
I understand how to finish this. but I want to know the intuition behind this. I always confuse when doing substitution, what is the dependent and independent variable, and to what variable I need to implicitly differentiate.
I can explain maybe some of the intuition.
The problem is pattern recognition. I will say that almost the only way (as far as ordinary nonmathematician scientific math users are concerned) to solve a differential equation is to know the solution! The so-called 'methods' are just ways of hammering equations until they look like something you recognise.
Here you have a function, (cos t)y, In which the two variables are mixed up. Nasty, maybe you haven't done anything like it before.
But maybe you have gone through what every scientist has to do, linear differentials of the form
Ay' + By = f(t)
With the stuff about general solution of the homogeneous equation, and the particular integral.
Maybe you could get some equation like that, at any rate you could get things involving y and its derivatives on one side and something involving only t on the other?
So you look you see you can get that by dividing the whole equation by y2.
Do that and your first term is y'/y2.
which you hopefully recognise as - d(1/y)/dt
So it looks like 1/y should be a more suitable variable than y.
then
##y'=\frac{-z'}{z^2}## is just the chain rule ##\frac{dy}{dt}=\frac{dy}{dz}\frac{dz}{dt}##
Ay' + By = f(t)
thanks but can I say the relation is $y(z(t))$? , both y and z is function of t. so $$1/y $$ is like the integrating factor right?, is there a way to find it in general for all problem? beside the first order linear differential equation, I know it use $\int e$
fiksx said:
thanks but can I say the relation is ##y(z(t))##? , both y and z is function of t. so ##1/y## is like the integrating factor right?, is there a way to find it in general for all problem? beside the first order linear differential equation, I know it use ##\int e##
Use double $ or # signs to delimit latex. The double $ gives display mode and the double # gives inline tex.
No, there is no general way for all problems. But this method works for a class of similar problems where you have a linear first order left side and a ##y^n## on the right side. In your case, as others have pointed out, you can divide by the ##y^2## giving$$
y^{-2}y' + \frac 1 {10}y^{-1} =\cos t$$Then if you change the dependent variable to ##z=y^{-1}##, you get a linear equation in ##z##. The same technique works for ##y^n## on the right side. It is called a Bernoulli substitution, I suppose because he must have first noticed that substitution.
thanks but I want to know when you change dependent variable from z to y ##z=y^{-1}##, when I differentiate it with respect x, why I need the chain rule? is it because $$z(y(t))$$ ? the relation is z->y->t?
You mean differentiate with respect to ##t##. Yes, ##z(t) = y(t)^{-1}## so ##z'(t) = -y(t)^{-2}y'(t)##.
1. What is substitution in a differential equation?
Substitution in a differential equation is a method used to solve equations by replacing one variable with another, often simplifying the equation and making it easier to solve.
2. Why is substitution used in differential equations?
Substitution is used in differential equations to simplify the equation and make it easier to solve. It can also help to isolate a specific variable or make the equation more manageable.
3. What is the independent variable in a differential equation?
The independent variable in a differential equation is the variable that is not dependent on any other variable. It is typically denoted by the letter x.
4. How do you substitute in a differential equation?
To substitute in a differential equation, you first identify the variable you want to substitute and then replace it with another variable or expression. This can be done by using the substitution rule or by rearranging the equation.
5. What are some common substitution methods used in differential equations?
Some common substitution methods used in differential equations include the substitution of variables, the substitution of trigonometric functions, and the substitution of power series. Other methods such as u-substitution and trigonometric identities can also be used.
