Substitution nath help
  • Thread starter jpd5184
jpd5184
76
integral of (2/(sqrt.(1-t^2))dt evaluated at sqrt.3 / 2 and root 2 / 2.
none
i believe its just substition.
u=t^3
du=3t^2
1/3 du = t^2
then you get 2/3(1/sqrt(1-u^2))dt
Answers and Replies
tiny-tim
25,838
255
hi jpd5184! :smile:
(have a a square-root: √ and try using the X2 icon just above the Reply box :wink:)
i don't understand how you got 2/3(1/sqrt(1-u^2)) from (2/(sqrt.(1-t^2))dt :confused:
jpd5184
76
lets see:
from the original equation:
u= t^3
du= 3t^2
(1/3)du=t^2
ok so i messed up. i accidently substituted u in for t^2 but u=t^3.
first i have to make sure my substitution values above are right and if using substitution is the right method for solving the problem. is it?
tiny-tim
25,838
255
first i have to make sure … if using substitution is the right method for solving the problem. is it?
substitution is the right way to do it,
but i doubt that u = t2 or t3 is going to help …
try getting it right, and see :smile:
8,293
Is this the integral?
[tex]\int_{\sqrt{2}/2}^{\sqrt{3}/2}\frac{2 dt}{\sqrt{1 - t^2}}[/tex]
It might be that you can do this one with an ordinary substitution, but this one is a natural for a trig substitution, with t = sin(u), dt = cos(u)du.
BTW, in your substitution, you had u = t3, du = 3t2. You omitted the dt. Omitting this will definitely cause problems in some substitutions, particularly trig substitutions.
jpd5184
76
that is correct, so what i have to do is use trig substitution. ill give it a try.
lets see:
u= arcsin
du= 1/(sqrt(1-t^2)) dt
i could then take the 2 outside the integral sign and get 2(integral of arcsin)
HallsofIvy
43,021
970
none
u=t^3
du=3t^2
No, du= 3t^2 dt
1/3 du = t^2
No, 1/3 du= t^2 dt and since there is no "t^2" in the numerator, you can only replace dt with 1/3 du/t^2- and you have to replace that t^2 by a function of u.
then you get 2/3(1/sqrt(1-u^2))dt[/QUOTE]
No, you don't. All you have done is put 1/3 in front and replace "t" with u.
If u= t^3, then t= u^{1/3} and t^2= u^{2/3} sqrt{1- t^2} would become sqrt{1- u^{2/3}}. Also the dt= du/t^2 becomes du/u^{2/3}. With that substitution, the integral becomes
[tex]\int \frac{du}{u^{2/3}\sqrt{1- u^{2/3}}}[/tex]
I don't think that is an improvement!
Substitution is right but much better is the substitution [itex]t= sin(\theta)[/itex]. That way, [itex]\sqrt{1- t^2}= \sqrt{1- sin^2(\theta)}= \sqrt{cos^2(\theta)}= cos(\theta)[/itex] and [itex]dt= cos(\theta)d\theta[/itex]. Also, you should change the limits of integration from t to [itex]\theta[/itex]. The upper limit is [itex]t= \sart{3}/2= sin(\theta)[/itex] so that [itex]\theta= \pi/3[/itex]. The lower limit is [itex]t= \sqrt{2}/2= sin(\theta)[/itex] so that [itex]\theta= \pi/4[/itex].
That way, the integral is
[tex]\int_{\pi/4}^{\p/3} \frac{cos(\theta)d\theta}{cos(\theta)}= \int d\theta[/tex]
which is very easy!
jpd5184
76
which is very easy![/QUOTE]
so does that mean the integral of (pi/3)-(pi/4)
just the upper limit minus the lower limit
8,293
Fixed the upper limit of integration.
[tex]\int_{\pi/4}^{\pi/3} \frac{cos(\theta)d\theta}{cos(\theta)}= \int_{\pi/4}^{\pi/3} d\theta[/tex]
which is very easy!
just the upper limit minus the lower limit[/QUOTE]
Yes.
jpd5184
76
so it would be pi/3 - pi/4
this would be 4pi/12 - 3pi/12
which would be pi/12 for the answer
since its a integral would it be pi/12 + c
8,293
This is a definite integral. The answer is a specific number. For indefinite integrals, you add the constant, but not for definite integrals.
jpd5184
76
pi/12 isnt giving me the right answer
8,293
There is a factor of 2 that got lost along the way. The integral should be
[tex]\int_{\pi/4}^{\pi/3} \frac{2cos(\theta)d\theta}{cos(\theta)}= \int_{\pi/4}^{\pi/3} 2d\theta[/tex]
Suggested for: Substitution nath help
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
