Understand Successive Bisection for Theorem Proof
  • Thread starter elliti123
  • Tags
    calculus
In summary: The limiting point L is zero, because no matter how small an interval you choose around 0, you will find terms of the sequence within it. For example, the interval (0, 0.0001) contains the terms 1/10000, 1/5000, 1/3333, 1/2500, 1/2000, 1/1667, 1/1429, 1/1250, 1/1111, 1/1000,..., all the way up to infinity.
elliti123
I have come across the proof of a theorem and i am unsure of some specific points in the proof so i hope someone could enlighten me. Here is the theorem and the proof straight from the book :
Theorem. Every bounded sequence possesses at least one limiting point.
Proof : We again determine the number in question by a suitable nest of intervals. By hypothesis there exists an interval $J_0$ which contains all the terms of the given sequence $(x_n)$. To this interval we apply the method of successive bisection and designate as $J_1$ its left or right half according as the left half contains an infinite number of the terms of the sequence or not. By the same rule we designate half of $J_1$ as $J_2$, and so on. Then the intervals of the nest $(J_n)$ so formed all have the property that an infinite number of the terms is contained in each, whilst to the left of their left endpoints there is always at most a finite number of points of the sequence. The point L thus defined is obviously a limiting point; for if $\epsilon$>0 is given arbitrarily, choose from the succession of intervals $J_n$ one, say $J_q$, whose length is < $\epsilon$. The terms of $(x_n)$, in number infinite, which belong to the interval $J_q$ then lie ipso facto in the $\epsilon$-neighbourhood of L, - which proves all that we require.
Now i can't exactly picture the successive bisection method on a line, so if anyone could please somehow explain it in more clear manner; since i can't exactly seem to get it from the text because it seems a bit vague. Secondly how exactly do the intervals $J_n$ contain infinite number of terms from the sequence $(x_n)$; is it a property of the method or do i not know something since by this method each interval should have a clear beginning and end which we do know, right?
Mathematics news on Phys.org
First, remember that you have an infinite sequence contained on a finite interval, so if you cut off a section of the interval that has a finite number of points, the remaining interval will necessarily have an infinite number of points.
You don't need to cut the interval in half each time, but it is convenient to say that the length of your n'th cut of the interval is ##\frac{1}{2^n}L## where L is the length of the original interval.
For example, you have the sequence x_n = 1/n defined on the interval [0,1].
Your first cut would be at .5, and you would see that there are a finite number of points in [.5,1] and infinite points in [0,.5].
Second cut would be applied to the interval [0,.5] and would be at .25. Similarly, the lower half would contain infinite points, so you would keep the interval [0,.25].
In this case it is clear that since ##x_n \to 0##, you will always keep the interval from [0, 2^n], and by successive bisection of the interval, you could get to a small enough neighborhood that there are infinite points in the sequence contained in an epsilon neighborhood.
Is there a specific example you are working on?
Also, what do you mean by:
A line is not a bounded sequence. It is a collection of points which are all infinitely close to one another, so every point on a line is a limit point, since there are infinite points located within an epsilon neighborhood of any point on the line.
First off, your single $ characters aren't doing anything but clutter up what you've written. For inline LaTeX, use two # characters at each end of what you want to be rendered. E.g, ##J_0##.
Here's an example that might help you visualize what's going on, with ##a_n = \frac 1 n, n \ge 1##. This sequence is contained in the interval [0, 1], so is bounded. The subinterval J1 = [0, 1/2] contains an infinite number of terms of this sequence. The other subinterval contains only two of the sequence values: 1/2 and 1. Continue dividing the subintervals into smaller and smaller half intervals.
No i am not it was just a theorem, but it seemed odd until now thanks it seems more clear. And about i mentioning the line; i just wanted to know how does the bisection looks like which is clear already by your explanation.
And if i have correctly understood the proof assumes that the bounded sequences actually have some part of their terms, let's say that an interval of the sequence could be finite and there is another which is infinite. Why is that?
There are an infinite number of terms in the sequence. So if any interval contains a finite number, the remaining points are still infinite and must be contained in the other interval.
This would only be true for a bounded sequence right?
No. If a sequence is bounded, then all of its terms are contained in a closed interval. Think about the example I gave - the sequence {1, 1/2, 1/3, ..., 1/n, ...}. All of the terms in this sequence are in the interval [0, 1].
Right. Applying the same logic, an unbounded sequence would be one that for any finite interval, there exist a infinite number of points outside the interval.
An example is ##x_n = n##. For any finite interval [0, K] where ##K<\infty##, there are a finite number of terms inside the interval and infinite points contained in the infinite interval ##[K, \infty)##.
There is not a lot you can do with unbounded sequences.
Interesting side note: Some sequences bounded to an interval contain all of its points. Simply order the rationals in ##[0,1] \cap \mathbb{Q}##. Every real number in [0,1] will be a limit point.
1. What is successive bisection for theorem proof?
Successive bisection for theorem proof is a mathematical method used to prove a theorem by dividing the given space or object into smaller and smaller parts until the desired result is achieved. This method is based on the principle that if a property holds for the original object, it also holds for the smaller parts of the object.
2. How does successive bisection work?
The successive bisection method works by dividing the given object or space into two equal parts and then repeating the process with each of the smaller parts until the desired result is achieved. This process is continued until the parts become small enough that the desired property can be easily proven.
3. What are the advantages of using successive bisection for theorem proof?
The main advantage of using successive bisection for theorem proof is that it can simplify complex geometric or mathematical problems by breaking them down into smaller and more manageable parts. This method also allows for a step-by-step approach to proving a theorem, making it easier to follow and understand.
4. Are there any limitations to using successive bisection for theorem proof?
One limitation of using successive bisection for theorem proof is that it may not always be applicable to every problem. This method is most useful for problems involving geometric shapes or constructions, and may not be as effective for other types of theorems.
5. What are some real-world applications of successive bisection for theorem proof?
Successive bisection for theorem proof has many practical applications in fields such as engineering, architecture, and computer graphics. It can be used to solve problems related to geometry, optimization, and design. This method is also commonly used in computer algorithms to efficiently divide and conquer large data sets or problems.
  • Math Proof Training and Practice
  • Linear and Abstract Algebra
