Suggestion on Transistors
Hello everybody,
I have an application which needs a pulse input ranging from +15v to -3v operating at 17.5 Mhz. The load capacitor is 150pF and the required rise and fall time of the pulse is 10nS. I am building a circuit with BJT's (both NPN and PNP) . I need some idea about the criteria for selection of BJT's available in the market.
Can somebody suggest some available NPN and PNP transistors which work in this range.
Also i tried searching for some RF transistors, but i was not sure if they are capable of handling such huge loads. The max collector current for RF transistors was around 50mA. I was not whether its possible to get such a strict rise/fall time with the given load. Can somebody comment on this calculations.
Also any other suggestion or reference links are also welcomed.
Regards
SNS
4,662
I used to use a 2N5770 npn for 1-2 ns risetime pulses, but it was only about a 0.75 volt to 1.5 volt pulse into 50 ohms. Are you talking about a pulse that goes from 15 volts to -3 volts? Into what impedance? To get the fastest pulses, always keep the transisitor conducting, but never in saturation.
Bob S
What is your application? Electro-optic modulator? Polarisation scrambler maybe?
Image Sensor Driver
The Physics Forums Way
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
