Sum and integral
  • Thread starter eljose
let be the function w(x) that only takes discrete values in the sense that is only defined for x=n being n an integer..then my question is if the integral:
[tex]\int_{-\infty}^{\infty}dxw(x)f(x)[/tex]
would be equal to the sum of the serie:
[tex]\sum_{n=-\infty}^{\infty}w(n)f(n) [/tex]
if the sum and integral would be equal imply that the function
[tex]w(x)=g(x)\sum_{-\infty}^{\infty}\delta(x-n) [/tex]
thanks...
Answers and Replies
HallsofIvy
41,833
956
Yes, if you mean the Stieljes integral.
Where the Riemann integral [itex]\int_a^b f(x)dx[/itex] is defined by partitioning the interval from a to b into many small intervals, {xi}, choosing x* in each interval, forming the sum [itex]\Sigma f(x*)(x_{n+1}- x{n})[/itex] and taking the limit as the interval is partioned into more and more intervals, the Stieljes (or Riemann-Stieljes) integral, [itex]\int_a^b f(x)d\alpha(x)[/itex] does the same thing but uses the sum [itex]\Sigma f(x*)(\alpha(x_{n+1})- \alpha(x{n}))[/itex] where [itex]\alpha(x)[/itex] can be any increasing function. If [itex]\alpha(x)[/itex] is differentiable, that gives simply the Riemann integral [itex]\int_a^bf(x)\frac{d\alpha}{dx}dx[/itex] but if [itex]\alpha[/itex] is a step function, say the greatest integer function, then it gives the sum [itex]\Sigma_{n=a}^{b} f(n)[/itex].
Hurkyl
Staff Emeritus
It sounds like your initial sentence is saying:
Let w be a function whose domain is the integers. I.E. w(x) is defined only when x is an integer.
In that case, the integral
[tex]\int_{-\infty}^{+\infty} w(x) f(x) \, dx[/tex]
is not even defined.
Let me pose another question, the one I think you meant to ask:
If we're given a function g that is defined on the integers (and not always zero), can we find a function w such that:
\sum_{n = -\infty}^{+\infty} g(n) f(n)
[/tex]
is true for all functions f? The answer is no.
However, if we let w be a distribution (or generalized function), then we can find such a w, and it can be given by the sum
[tex]
w(x) = \sum_{n=-\infty}^{+\infty} g(n) \delta(x - n)
[/tex]
If g is also defined at every real number, the above expression is indeed the same as
[tex]
w(x) = g(x) \sum_{n=-\infty}^{+\infty} \delta(x - n)
[/tex]
Related Threads on Sum and integral
  • Last Post
  • Last Post
  • Last Post
13K
  • Last Post
  • Last Post
