Sum equals product problem
  • Thread starter tony24810
tony24810
42
If the product of the numbers R and 11/S is the same as their sum, find the value of S.
N/A
I am suspecting that the only set of 2 numbers that have the same sum and product is 2 and 2.
So I guess R is 2, 11/S is also 2.
That gives S = 5.5
Please will anyone verify if this is correct?
Answers and Replies
dirk_mec1
761
Is this the complete question?
Enigman
665
307
It probably isn't. Graph by wolfram alpha attached.
Also integer solutions if thats what the question is asking: (-11,12);(-1,22);(11,10).
Source:http://www.wolframalpha.com/input/?i=x+11/y=x*(11/y)
EDIT: P.S. to solve a equation in two variables you always need two equations.
haruspex
Insights Author
7,891
Assuming, as others have suggested, that R and S are integers, what equation in which all terms are integers expresses the given condition? Can you deduce anything by thinking about factors?
tony24810
42
That was the complete question, extract from Olympiad.
tony24810
42
That's cool, haven't thought of the solutions you create.
I didn't understand your graph though.
Is there an algebra way of solving this though? I don't think graphical calculator is allow in exam.
tony24810
42
I am not sure what you mean by 'thinking about factor', I don't know the actual value of R and S so I cannot determine their factor. Is there any specific theorem that I should try?
the equation I made was:
R + 11/S = R x 11/S
which got me nowhere.
Dick
26,263
619
R + 11/S = R x 11/S
That's fine, but that equation has many solutions. R=2, S=11/2 works, and so does R=3, S=22/3. Etc, etc. Can you post a reference to the exact Olympiad question?
Ray Vickson
Dearly Missed
10,706
1,722
R + 11/S = R x 11/S
That gives you RS + 11 = R*11, or 11*(R-1) = R*S. Thus, R*S must be divisible by 11, and that suggests looking at some simple values like R = 11 or S = 11, etc, assuming you want positive integer values of R and S. If all you want are real values, you can just put S = 11*(R-1)/R and let R be anything you want (but not zero).
Enigman
665
307
A reference would be nice...Were there options in the question.
The graph just shows that there are infinite solutions possible. ie. Each point is a solution
Ignore the zig-zag lines at x axis, its just Mathematica having a fit.
tony24810
42
Here's the paper.
Well I also failed to do question 2, please help if possible^^. thanks!
tony24810
42
O yes this is cool!
I have actually got to the equation you wrote, but didn't realise that it means infinite sets of solution!
Thanks!
tony24810
42
There weren't options in the question.
I have attached the original document in previous post.
Some of the questions are somewhat confusing I think.
Like question 3, I think the answer can only be an expression, not a value, but it doesn't say. I think the answer is 11/6 log2 (Q) ], but there's no solution come with the document, quite annoying.
Enigman
665
307
Well, as you have to find four values: P Q R S
You will have to solve third question for R first before attempting the fourth one which requires the value of R to get S. To get R you will have to get Q and for Q you will need P.
So start from the start and solve question 1 for P first plug it into q.2 get Q plug into q.3 get R and use it finally for S.
ehild
15,543
1,915
Very clever! So it is not four problems but a single one:biggrin:. And everything fits. R and S are really positive integers.
ehild
Enigman
665
307
ehild
And cruel, imagine the plight of the guy who does everything correctly except the first one...no marks for steps just answers.
Also it has a time multiplication factor, never seen that before.
EDIT: HEY! ehild, you just told OP the answer!
ehild
15,543
1,915
I do not think so... You gave the principle of solution. :approve: It was very clever of you!
ehild
tony24810
42
OMG i feel so unintelligent, i thought these questions are all separate!!! No wonder I don't understand half of the questions in other events...
well thanks for pointing it out anyway
Curious3141
2,850
88
Rather nasty of them to chain 4 questions into 1, but thankfully, all of them are fairly elementary. What level is this for, just out of curiosity?
Suggested for: Sum equals product problem
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
16K
  • Last Post
