Sum(from 1 to infinity) of 8 / x^2(4+ln(x))
  • Thread starter rick906
  • Tags
    Infinity
In summary: The result is correct, but I don't know why the notation says that the zeta function should be divergent at zeta(0.5). I'm not sure if that's what's supposed to happen or not.Thanks for asking!
rick906
Hi all,
I'm stuck on this problem, I can't solve it :confused:
Does anybody have the fainest idea of how to solve?
Thanks all
It can be integrated in terms of the exponential integral, and an initial portion can be calculated directly. Unfortunately this is still very slow to converge.
You could try to integrate the expession indefinitely using integration by parts and then apply the limits.
Do you mean sum or integral? I know you wrote sum but usually use i,n,j etc for sums, and x for a real valued variable that you integrate over.
Oh sorry,it is a sum, not an integral, I don't know why I put x instead of n.
I'm not sure to understand what you people mean by 'integrate and then apply the sum'
Technics I have learned for solving a sum are : Reinman (p-series), the integral test, comparision test, ratio test, the n^th root test and those for alternating series.
I've tried with all of them... nothing worked.
However, the one that seemed the most possible was the integral test (was that what you were talking about?). So, I've checked that f(x)>0, f(x) is continuous and that it decreases at a point. Unfortunately, I'm not able to do the integral... even mathematica gives me strange things (see attachment).
Anyone's got a lead? Or maybe a technic I'm not aware of?
Thanks
Comparison test works here.
Mathematica gave you an answer in terms of the exponential integral, as I mentioned in my first post. (I also used Math'ca to solve it. :shy:) I summed the first ten million terms then applied the integral over the rest, but I'm not sure how good my convergence was since the area seemed to grow significantly (> 1e-6 as I recall) when I moved from the first million to ten million; I expected the integral would have done a better job as estimator.
Well um Rick, look solving a sum means to find what numerical value it converges to.
You said that you wanted to solve the sum and not an integral (but then contradicted yourself by posting an integral from mathematica!) but then went on to mention convergence tests?
Look did you really mean to say that you wanted to decide if the series converges or not?
The integral seems 'obviously' applicable here, as a slight transformation of the integral (plus some finite computation, if you want a better answer) can give bounds on the sum, since the function is strictly decreasing over the range.
Here's the bound I have (check this before using!) for f(x) strictly decreasing:
[tex]\int_n^{\infty}f(x)dx<\sum_{k=n}^{\infty}f(k)<f(n)+\int_n^{\infty}f(x)dx[/tex]
So take the sum up to n-1 for some n, then add the integral; that gives the lower bound, and adding f(n) gives the upper bound.
Hi back
Ouh, I was so nervous that I forgot to mention : yes, I'd like to know if the sum converges or diverges.
As for CRGreathouse, I haven't learned that technic, so I'm not sure if the teacher will allow me to use it in a test.
Vid says
I've tried it many times, can you please tell me what have you compared it to.
Thanks again all, I appreciate your fast replies.
Rick
8/(x^2(4+ln(x)) < 8/x^2
Ouhhh
It's so true. I had totally forgotten that p-series with p>1 converges (I thought it was the opposite!)
So I think the problem is solve thanks to you all (especially Vid) and I've scanned the problem, if anyone could just check if everything's alright, it'd be really great (attachment).
Thanks (infinite thanks, that is)
Rick
Wait, you just wanted to see if it converged? I assumed that it converged from the beginning as a first step toward calculating it -- it's clearly less than [itex]8\zeta(2)[/itex] as Vid said.
Well, yes, I only wanted to know if it converges.
I wonder how you knew it from the beginning...maybe something I have not learned yet...
By the way, I really do not understand those signs... maybe this is the notion I do not know.
Anyway, are my steps and my result right?
Thanks again dudes.
Thanks, it confirms that this is something we haven`t learned (not yet, anyway).
I find something strange with the Riemann zeta function: it says that:
[itex]
\zeta(1)
[/itex] = infinity ok we know this one because it's the harmonic serie (p`s equal or smaller than 1 diverge)
but then, [itex]
\zeta(0.5) = 1.46...
[/itex] is that not supposed to be a p-serie with p=0.5 and, therefore, diverge?
This really confusses me.
Otherwise, if you could confirm my steps (about 2 posts of mine ago), that would really make me feel more confident about that.
Thanks again to all of you.
You can compute the summation exactly. I'll give you a hint. Expand the zeta function [tex]\zeta(s)[/tex] around s = 2. You also know that
[tex]\zeta(2 + \epsilon) = \sum_{n=1}^{\infty}\frac{1}{n^{2+\epsilon}}[/tex]
Now expand the summand to first order in epsilon. :cool:
Well, they use some clever trick to define the Riemann Zeta functions where it normally isn't defined. The summation definition only works for real numbers > 1.
Therefore, it's right (for my level of knowledge, at least) just to say that Sum of 1/n (and n power of something smaller than 1) diverges?
Count Iblis, I would have done what you are saying if I had understood it :rofl: In fact, I don`t know that zeta series quite well now (learned about it 5 mins ago :rolleyes:) But hey, thanks anyway !
Also, have you people check my steps (about 3 posts back now), it's an attached image.
Thanks Thanks Thanks.
Can anybody just check my solution and tell me if all the steps are OK or if there is a mistake somewhere...and of course check the result... please
Thanks :wink:
Thanks :wink:
I thought your solution was excellent. Correct reasoning, step by step logic, no holes, presented linearly from the beginning. It's fantastic. The only thing was that you could have written "by the comparison test..." but I think it's good.
Thanks dude!
Just one thing: you said you 'Thought' it was correct... did you mean you 'think' it's correct or that you thought it was but then you noticed a mistake?
Lol, I know it was linearly presented, but usually it just ain't that way... I made an effort of presentation on this one :rofl:
Thanks again
No mistake it's fine.
Thank you, I was really worried about this problem, now I feel better :)
I'd like to thank everyone for helping me solving this problem (which doesn't look hard anymore).
Hope that I'll be able to help other people on this forum.
I'm curious. How do you get from the crude [tex]n^\epsilon[/tex] to [tex]\log n[/tex]?
The derivative of the Riemann-Zeta function has a log n term and it appears when you Taylor expand the fn as he suggested doing. The only thing is that the log n term appears in the numerator, I wonder how you watch it to the original series? Well the derivative of the Riemann-Zeta function at 2 is known exactly if you can end up matching that series with the original.
Yes, I was wrong. The factor 4+ln(n) has to be in the numerator for this to work. See also http://mathworld.wolfram.com/Glaisher-KinkelinConstant.html"
What is the significance of the mathematical series "Sum(from 1 to infinity) of 8 / x^2(4+ln(x))"?
The series represents the sum of infinitely many terms, each of which is a fraction with the denominator as the square of x multiplied by the natural logarithm of x, and the numerator as a constant 8. This series is important in mathematics as it demonstrates the concept of an infinite series and how it can converge or diverge depending on the values of x.
What is the limit of the series as x approaches infinity?
The limit of the series is 0 as x approaches infinity. This can be shown by using the limit comparison test, where the series can be compared to 8/x^2 which is a known convergent series.
Can the series be simplified or written in a different form?
Yes, the series can be rewritten as 2/ln(x) + 2/(4+ln(x)) + 2/(2ln(x)) + 2/(3ln(x)) + ... which can be further simplified to 2*sum(from 1 to infinity) of 1/(nln(x)) where n is the index of summation. This form may be easier to work with for some calculations.
What is the convergence behavior of the series?
The series is conditionally convergent, meaning that it converges but not absolutely. This can be shown by using the alternating series test, where the series can be rewritten as (-1)^n * 8/(x^2(4+ln(x))) and the terms alternate in sign and decrease in magnitude as n increases.
Can the series be used to solve real-world problems or model natural phenomena?
While the series itself may not have direct applications, the concept of infinite series and convergence can be applied to various real-world problems and phenomena. For example, in physics, the concept of infinite series is used to model physical systems and make predictions about their behavior.
