Puneeth423
- 51
1/5 + 1/7 + ..... + 1/401
The sum of an HP series is often used to find the total amount of a particular quantity that increases or decreases at a constant rate over a given number of terms.
The formula for calculating the sum of an HP series is S = a/(1-r), where S is the sum, a is the first term, and r is the common ratio between consecutive terms.
Yes, the sum of an HP series can be negative if the first term (a) is negative and the common ratio (r) is greater than 1 or less than -1.
The common ratio represents the factor by which each term in the series increases or decreases. It is a crucial factor in determining the behavior and convergence/divergence of the series.
The sum of an HP series can be used to calculate compound interest, population growth, and other phenomena that follow a constant rate of increase or decrease. It is also used in finance, economics, and other fields to predict future values based on historical data.
