Sum of sides of n polygons in quadrilateral is no more than 4n
In summary, the problem being discussed involves a convex quadrilateral that is cut into convex pieces by a finite number of lines. The goal is to decompose the quadrilateral into non-overlapping convex polygons, with each polygon containing only one of the original convex pieces and the total number of edges not exceeding four times the number of convex pieces. While it may seem that this can always be achieved, there is a hidden assumption that needs to be proven in order for the result to hold for all partitions.
Mr Davis 97
1,462
44
Say that we have a convex quadrilateral, and then draw a finite number of lines inside of it. Then, it's clear that the quadrilateral is now made up of a finite number of, say, ##n## polygons. Let ##s_i## be the number of sides of polygon ##n##. Is it possible that ##\sum s_i > 4n##?
N/A
I can construct examples that are less than or equal to ##4n## quite easily, but for the life of me I cannot come with example where it's greater than
Mr Davis 97 said:
Problem Statement: Say that we have a convex quadrilateral, and then draw a finite number of lines inside of it. Then, it's clear that the quadrilateral is now made up of a finite number of, say, ##n## polygons. Let ##s_i## be the number of sides of polygon ##n##. Is it possible that ##\sum s_i > 4n##?
Relevant Equations: N/A
So why don't you try and prove that it is impossible? Also: do the lines have to cut the quadrilateral? And how? Otherwise I could simply draw an 5n polygon inside of it, or with one side being part of a side of the quadrilateral. And has it to be convex?
A line in this case is a segment from one side of the quadrilateral to the other.
Here is the problem I am actually trying to solve: Let ##Q## be a convex quadrilateral which is cut into convex pieces (cells) by a finite number of lines. For any collection ##(Q_i)_1^n## of these cells, decompose ##Q## into nonoverlapping convex polygons ##(R_i)_1^n## so that ##Q_i \subset R_i## for every ##i##, and ##\sum s_i \le 4n##, where ##s_i## denotes the number of sides of ##R_i##.
Here is my question: When I draw some lines the resulting ##(Q_i)_1^n## always seem to satisfy that ##\sum s_i \le 4n##, so why do we need the ##(R_i)_1^n## at all?
I see the need to rule out overlapping to avoid a multiple count, and to remain convexity. It also rules out, that a cell is considered as a part of two polygons. So I'd say it's a technical statement to rule out double counts.
The set of partitions of the quadrilateral into the ##Q_j## is a proper subset of the set of all partitions into ##R_j##. Consider the partition of the square with diagonally opposite corners at (0,0) and (2,2) into the following three convex polygons:
  1. ##R_1##: triangle with vertices (0,0), (2,0), (1,1)
  2. ##R_2##: quadrilateral with vertices (0,0), (0,2), (1, 2), (1,1)
  3. ##R_3##: quadrilateral with vertices (2,0), (2,2), (1, 2), (1,1)
That partition cannot be made by a set of lines cutting the square, without combining elements. We can partition the square into six triangles by cutting with the lines ##y=x,\ x=1,\ y+x=2##, but we need to combine pairs to get the partition above.
So proving the result for the ##R_j## partitions is a stronger theorem than proving it for only the ##Q_j## partitions.
However, it should not be hard to show that every R partition can be formed by amalgamating elements of a Q partition, and that amalgamating always reduces the edge sum. So once those two are proved, plus the lemma of the next paragraph, the problem can be reduced to proving that the result holds for all S partitions.
I note that the problem contains a hidden supposition: that for every Q partition there exists at least one R partition such that every R cell contains exactly one Q cell. That that can be done is not immediately obvious, so a lemma is needed to show that this can be done. It is easy to see that the quad can be partitioned into n polygons, each containng exactly one Q cell, but not necessarily that it can be done so that each of those polygons is convex.
EDIT: It turns out to be easy to prove the problem stated in the OP. Not so easy to prove the problem stated in post #3. I do not yet have a proof of that harder problem. Note also that a full statement of the harder problem says that, for every Q partition by straight lines and list of n Q-cells, there exists a partition of Q into convex polygons (R-cells), formed by amalgamating cells in the Q partition, such that each R-cell contains exactly one of ##Q_1,...,Q_n## and the edge total from that R partition does not exceed four times the partition size.
It does not say that every partition into convex polygons such that each R-cell contains exactly one of ##Q_1,...,Q_n## satisfies the four-times relationship. We can construct a counterexample to that by tesselating the square with hexagons and cutting each corner of the square with a little snip line near the corner, so that every R cell contains exactly one Q cell.
1. What does the statement "Sum of sides of n polygons in quadrilateral is no more than 4n" mean?
The statement means that if we have n polygons (shapes with straight sides) placed inside a quadrilateral (a four-sided shape), the total number of sides of all the polygons combined will not exceed 4n. This is a mathematical property that applies to any number of polygons within a quadrilateral.
2. Can this statement be applied to any type of quadrilateral?
Yes, this statement can be applied to any type of quadrilateral, including squares, rectangles, parallelograms, trapezoids, and kites. As long as the shape has four sides, the statement will hold true.
3. How is this statement useful in mathematics?
This statement is useful in mathematics because it helps us understand the relationship between the number of polygons and their sides within a quadrilateral. It can also be used to solve various problems involving quadrilaterals, such as finding the maximum number of sides that can be placed inside a given quadrilateral.
4. Is there a limit to the number of polygons that can be placed inside a quadrilateral?
No, there is no limit to the number of polygons that can be placed inside a quadrilateral. As long as the polygons are of different sizes and shapes, the statement will hold true. However, as the number of polygons increases, the size of each polygon will decrease, eventually reaching a limit where the polygons become infinitely small.
5. Can this statement be extended to other shapes besides quadrilaterals?
Yes, this statement can be extended to other shapes besides quadrilaterals. For example, the sum of sides of n polygons in a pentagon is no more than 5n, and in a hexagon, it is no more than 6n. This pattern continues for any regular polygon, where the sum of sides of n polygons is no more than n times the number of sides in the regular polygon.
  • Set Theory, Logic, Probability, Statistics
  • Precalculus Mathematics Homework Help
9K
