Find Closed-Form Expression for Summation of n^2
  • Thread starter mnb96
  • Tags
    Summation
In summary: The conversation discusses how to find a closed-form expression for the summation Q_N, which is the sum of squares from 1 to N. The solution is N(N+1)(2N+1)/6 and the method involves summing equations and using a telescopic sum. Another user also mentions an equation form for the sum of squares.
mnb96
715
Hello,
could anyone give me a hint on how to find a closed-form expression for the following summation:
[tex]Q_N = \sum_{z=1}^N z^2[/tex]
where z are positive integers from 1 to N.
Thanks.
The solution is N(N+1)(2N+1)/6. The trick is simple: take the equations: (k+1)^3-k^3=3k^2+3k+1, sum them up from k=1 to N.
Uhm...you mean:
[tex]\sum_{k=1}^N \left( (k+1)^3-k^3 \right) = \sum_{k=1}^N \left( 3k^2+3k+1\right) [/tex]
But how can this help, if we don't know the value of the leftmost summation?
Evaluating the rightmost term also requires evaluating a summation of k2, which is what we are trying to find :confused:
You do know, it's a telescopic sum and equals (N+1)^3-1. After that, you get an equation for Q_N
Ups! that's true...I should have noticed it immediately. Thanks.
mnb96 said:
Hello,
Thanks.
Also note the following equation form: (n^3 - n)/24. The sums of squares are a special case of this equation form, and incidentally, there are only 3 integers in N | the sum of squares is also square. This holds for 0, 1, 24 and no other.
- RF
1. What is a closed-form expression for summation of n^2?
A closed-form expression is a mathematical formula that gives the exact value of a sum or series without the need for iteration or approximation. In this case, the closed-form expression for summation of n^2 is n(n+1)(2n+1)/6.
2. How do you derive the closed-form expression for summation of n^2?
The closed-form expression for summation of n^2 can be derived using mathematical induction or the method of differences. Both methods involve manipulating the equation and using algebraic techniques to simplify it into the closed-form expression.
3. What is the significance of finding a closed-form expression for summation of n^2?
Finding a closed-form expression for summation of n^2 allows us to easily calculate the sum without having to manually add each term. It also allows us to analyze the behavior of the sum as n approaches infinity or for different values of n.
4. Can the closed-form expression for summation of n^2 be applied to other series?
Yes, the closed-form expression for summation of n^2 can be applied to other series with the same general form, such as summation of n^3 or n^4. However, the specific coefficients and exponents will differ depending on the series.
5. Can the closed-form expression for summation of n^2 be used to find the value of irrational numbers?
No, the closed-form expression for summation of n^2 can only be used to find the value of natural numbers and integers. It cannot be used to find the value of irrational numbers such as pi or e.
  • Linear and Abstract Algebra
  • General Math
  • General Math
