Solve Summation Problems: Please Help!
  • Thread starter axellerate
  • Tags
    Summation
In summary, the conversation involves a post about summation problems and equations that make no sense, with one person claiming to be a medical student and another bashing the original post for being incorrect. The validity of the equations is questioned and the inappropriate behavior of one of the posters is addressed.
axellerate
Summation Problems! Please Help!
My geography prof assigned these... believe it or not. Its a quiz and its worth 5% of our mark.
1) Σi^4 = 1^xi Variables - n=4 x1=1 x2=6 x3=9 x4=17 (i think its 4)
2) (Σi^4=1^xi)^2 n=4 x1=3 x2=10 x3=9 x4=12 (i think this one is 4 also)
3) Σi^2= 1Σj^2 = 1^xij n=2 m=2 x11=2 x12=12 x21=4 x22=17 (i haven't the faintest idea...)
4) Σi^3= 1 xi/2 n=3 x1=3 x2=16 x3=6 (i think this one is 12.5)
5) Σi^n=1 xi/zi n=3 x1=14 x2=19 x3=16 z1=4 z2=9 z3=6
(i think the answer is apprx 8.28)
I have no idea why my geography teacher is giving us this quiz... i am not a math major. I have to round all answer to 2 decimal places if rounding is possible in the solution. I don't require the work as its an online quiz. But if u want to include it, all the better.
Thanks in advance.
please use latex typeset to represent such equations. its a pain to read them or get what the question is.
Whether you are a math major or not, you should know enough arithmetic to at least understand what these are asking.
Σi^4 = 1^xi
This makes no sense. Σi^4 would mean (1)^4+ (2)^4+ (3)^4+ ... but where do you stop? "n= 4" makes no sense because you did not write an "n" in your formula. If you mean "i runs from 1 to 4" then it is (1)^4+ (2)^4+ (3)^4+ (4)^4, then you just need to do the multiplications and the final addition. It's just arithmetic.
I can make no sense out of 1^xi at all. 1 to any positive power is just 1.
HallsOfIvy,
My friend used my account to post this. I am currently a Medical Student, and I have never encountered the Summation (Σ) sign. Knowing arithmetic is one thing; but understanding what the equations mean is another. You must be taught what the variables / letters etc... mean. One cannot assume. The equations are written perfectly, and Σi^4 is a standardly used in summation problems. I suggest you do a little research before bashing one work. BTW: The n variable does stand for something. Why don't I let Mr.Arithmetic figure it out. I mean, you should know what it means... You should know enough arithmetic to understand the variables right?
Also, my buddy in forth year mech. engineering ended up solving each problem flawlessly with no issues.
The Guy that Doesn't understand arithmetic.
Axellerate
axellerate,
Notwithstanding that you are a medical student, or that your friend posted it, the problems in the first post make no sense. For example, in the first one, Σi^4 = 1^xi, I know what the summation on the left side means, but don't see how it could possibly be equal to what's on the right side. And what do the variables have to do with this?
axellerate said:
HallsOfIvy,
... I suggest you do a little research before bashing one work. BTW: The n variable does stand for something. Why don't I let Mr.Arithmetic figure it out. I mean, you should know what it means...
Axellerate
I suggest that you, Mr. math illiterate future MD, don't need to show up here and tell posters that have probably forgotten more mathematics than you ever knew, that they need to "do a little research" because they can't make sense of a nonsense post.
"The equations are written perfectly,"
Not in the first post - they are garbled to the point of being crap.
"Also, my buddy in forth year mech. engineering ended up solving each problem flawlessly with no issues."
I'd be amazed at that, but possible. Look at the way the problems he saw, and compare to what was posted here. How dissimilar in appearance are they?
"One cannot assume. The equations are written perfectly, and Σi^4 is a standardly used in summation problems. I suggest you do a little research before bashing one work. BTW: The n variable does stand for something. Why don't I let Mr.Arithmetic figure it out. I mean, you should know what it means... You should know enough arithmetic to understand the variables right?"
Neither HallsofIvy nor Mark44 made an assumption; both stated facts. You seem to be the one making the assumption: if you are unfamiliar with the mathematics, as you yourself claimed, it is not possible for you to know that that equations are correct. You also assumed that these two do not know what they are doing - another assumption, equally as false as the first.
I'll take you at your word that you are a medical student - and state given your apparent arrogant attitude, you are going to suck at being a doctor. Assumption or prophecy? I don't know.
What is a summation problem?
A summation problem is a mathematical problem that involves finding the sum of a series of numbers. It is often represented using the sigma notation, ∑, and can involve a wide range of mathematical operations.
How do I solve a summation problem?
To solve a summation problem, you can use several methods such as the formula for the sum of an arithmetic series, the formula for the sum of a geometric series, or the properties of summations. It is important to carefully read and understand the problem before choosing the appropriate method.
What are some common mistakes when solving summation problems?
Some common mistakes when solving summation problems include forgetting to consider the upper and lower limits of the summation, not understanding the properties of summations, and making calculation errors. It is important to double-check your work and make sure you understand the problem before solving it.
What are some tips for solving summation problems?
Some tips for solving summation problems include carefully reading and understanding the problem, identifying and using the appropriate formula or method, double-checking your work, and practicing with different types of summation problems to improve your skills.
Where can I find resources to help me solve summation problems?
There are several online resources available to help you solve summation problems, such as math websites, tutorial videos, and online forums. You can also consult with your teacher or professor for additional help and guidance.
