Homework Help: Summing a geometric series
  1. Feb 19, 2012 #1
    2. Relevant equations
    a(1-r^[n+1])/(1-r)
    3. The attempt at a solution
    So I wrote it as e^(-iNz) [1 + e^(iz) + e^(2iz) + ... + e^(2iNz)]
    Let r = e^(iz), a=e^(-iNz)
    a [1 + r + r^2 + ... + r^(2N)]
    From here I'm not sure what to do. I tried letting n=2N, and then letting the bracket be equal to (1-r)^-1 but I couldn't get much out of that. Tried using the formula, can't get anything. I just get loads of e's everywhere, and no way to get rid of the cos if I put them in trig form. Really stuck.
  3. Feb 19, 2012 #2
    Once you have applied the formula for the sum of a geometric series, you will have a fraction. The trick is to multiply the numerator and denominator of the fraction by an appropriate factor. It's hard to say more without giving the whole thing away, but you can probably work backwards from the answer if you can't figure out the factor otherwise.
  4. Feb 19, 2012 #3
    vela
    Staff Emeritus
    Education Advisor
    Hint: Use ##\sin x = \frac{e^{ix} - e^{-ix}}{2i}##. Can you tweak the numerator and denominator to look like that using awkward's suggestion?
  5. Feb 20, 2012 #4
    Thanks a lot for the help, totally sorted now. Had forgotten that identity, was all I needed, cheers you two.
