Sun's Evolution: Tracing the Evidence from Red Dwarfs to the Present
In summary: For example, we think that when a star becomes a red giant, it starts to lose the ability to fuse elements heavier than helium. This might end up causing the star to explode as a supernova. However, we still have a lot to learn about these things. Just for general knowledge.. the vast majority of temporal evolution in astronomy is deduced not from direct observation but from large representative samples. That is, we have nowhere near enough time to stare at a star as it evolves along the main sequence. Rather, we can look at millions of stars which presumably were all created out of similar environments, and (assuming they all evolve similarly) get a picture of the temporal evolution by seeing groups of stars which are young, medium,
MathematicalPhysicist
371
What is the empirical evidence that the red dwarves we observe nowadys were once like our sun in magnitude and luminosity?
Thanks in advance for any reference.
Astronomy news on Phys.org
Observational evidence from a few billion years ago is rather scarce.
Stellar evolution is based on modelling and nuclear physics along with observations to fix the parameters. If you model the life of a star and the predicted numbers of stars of each type at a point in time match the number of each type we see now then the model is probably good.
So it's kind of ad hoc isn't it?
Like every modelling in science, I guess.
None, because red dwarfs are not evolved yellow dwarfs.
Red dwarfs are between .08 and .4 Msun [solar mass] stars. They are main sequence hydrogen burning stars, but much cooler and less luminous. The are also much longer lived. A star of 0.1 Msun would have a lifetime of 300 times that of the Sun, or about 3 trillion years. Because of their low luminosities, red dwarfs are fully convective. Their core energy is carried to the surface by gas currents. This also fully mixes hydrogen and helium so they can burn all of their hydrogen. When a red dwarf has used up all its hydrogen, it will simply collapse to form a helium white dwarf. It bypasses the red giant phase typical of larger stars [which incidently is the fate of our sun].
Just for general knowledge.. the vast majority of temporal evolution in astronomy is deduced not from direct observation but from large representative samples. That is, we have nowhere near enough time to stare at a star as it evolves along the main sequence. Rather, we can look at millions of stars which presumably were all created out of similar environments, and (assuming they all evolve similarly) get a picture of the temporal evolution by seeing groups of stars which are young, medium, and old. See: HR diagram.
If you think this is not a valid strategy of deduction, I strongly suggest you look into it more.
They weren't. I think you mean red giants.
Anyhow, what you can do is to take a snapshot of all of the stars in a cluster. Since all of the stars in a cluster were born at roughly the same time, you get a snapshot of how stars at a certain fixes age look like, and what you see are stars on the main sequence up to a certain mass, and then they turn off into red giants.
But, our deductions about stellar evolution appear to be sound. We deduce their properties based on particle physics and observation. We have detected no significant observational deviations from particle physics models to date.
There's relatively little particle physics involved. You have some nuclear physics, but it's really hydrostatics, thermal transport and convection that you need to explain stars. The only thing that really involves particles is the photon-electron scattering that results in opacity.
We have also been able to look inside a good fraction of the sun using helioseismology. This is analogous to our use of seismology here on Earth to determine the interior structure of our planet. We have found that our models of the sun's interior are more or less correct.
That's because when we observe deviations we change the model (i.e. what happened with solar neutrinos). Not that there is anything wrong with that...
One question that comes up is how robust a result is. You can run a solar simulation and then ask the computer what you have to do so that a one solar mass star *doesn't* end up being a red giant. It turns out that you have to radically change things in ways that are likely to be excluded by experiment.
Also, based on globular clusters, we think we have a good handle on how single star one solar mass stars work. For massive stars, and what's more for massive stars with extremely low non-hydrogen/helium content, there is still a lot we don't know.
1. What evidence supports the idea that the Sun is evolving?
There are several lines of evidence that support the idea of the Sun's evolution. One major piece of evidence is the observation of sunspots, which are temporary dark spots on the surface of the Sun caused by changes in its magnetic field. These sunspots have been observed to follow an 11-year cycle, indicating that the Sun's magnetic field is changing over time. Other evidence includes observations of changes in the Sun's luminosity and spectral composition over time, as well as the presence of heavier elements in the Sun's atmosphere compared to its core.
2. How does nuclear fusion play a role in the Sun's evolution?
Nuclear fusion is the process by which the Sun produces energy, and it is a key factor in its evolution. As hydrogen is fused into helium in the Sun's core, the composition of the Sun's interior changes, leading to changes in its structure and energy output. Over time, as the Sun's supply of hydrogen decreases, it will continue to evolve and eventually die.
3. What is the main theory for how the Sun will evolve in the future?
The prevailing theory for the Sun's future evolution is that it will continue to fuse hydrogen into helium until it runs out of hydrogen fuel in its core. At this point, the core will contract and heat up, causing the outer layers of the Sun to expand and cool. This will result in the Sun becoming a red giant, eventually engulfing and destroying the inner planets of our solar system.
4. How do scientists study the Sun's evolution?
Scientists study the Sun's evolution through a combination of observational data and theoretical models. Observations from telescopes and spacecraft provide valuable information about the Sun's current state and changes over time. Theoretical models, based on our understanding of physics and stellar evolution, are used to make predictions about the Sun's future evolution.
5. Is the Sun's evolution unique to our solar system?
No, the Sun's evolution is not unique to our solar system. All stars, including our Sun, evolve over time as they consume their fuel and undergo internal changes. The exact details of each star's evolution may vary depending on its mass, composition, and other factors, but the overall process is the same for all stars.
  • Astronomy and Astrophysics
  • Science Fiction and Fantasy Media
