Superconductivity: Zero Resistance & Its Effects
  • Thread starter abdullahbameh
  • Tags
    Conductivity
In summary: If all the atoms in a material were to line up perfectly in a single direction, then the material would be a perfect diamagnet and no current would flow.
abdullahbameh
is it really in super coundactivity the resistance is ZERO and how it become ZERO is it because of law temperature or the applied voltage and does that mean if we have a current in circuit of super conductor it will go for ever or not and why?
and why we can not have super conductivity from noble metals like silver or gold?
Yes, in a perfect superconductor the dc resistance is zero*
And yes, a current would circulate forever.
There is no "simple" reason why the gold, silver and copper do not become superconducting, it just happens to be the case that they have a crystal structure that means they are not BCS superconductors even under pressure (and there are also other elements that do not become superconducting). Note that there is no simple correlation between the conductivity of a material and its superconducting transition temperature
*In real superconductors there are always mechanisms (such as flux flow, hopping etc) that cause some loss of energy so the dc resistance is not actually zero, just very,very low. The decay time for the supercurrent can be of the order of years.
the reply above is good. I think he is major in physics
he is post doc...
...and if gold and silver had super conducting property, then it would've been the most expensive super condutors ever!
i have a question like this: when a superconductor is on the meissner state, how does it interact with a magnet near it ? i think it maybe interact through the supercurrent, but how does the current circulate?
it interacts with a magnetic field by repelling it, no matter which pole of the magnet faces the superconductor. It does so be using surface currents that generate an equal but opposite field to the applied field from the magnet. Also, are these surface currents superconducting or supercurrents in that they are flowing without resistance? Could one say they result from Lenz's law?
They are supercurrents, but it would not be accurate to say that they arise due to Lenz's law. If they did, you would not observe the Meissner effect. People seem to mistake the Meissner effect with perfect diamagnetism. The former is more than the latter. Specifically, when a superconductor is put into a magnetic field whilst above its Tc, and *then* cooled all the while in the field, it will spontaneously exclude the magnetic field at Tc. Thus you see that it is not a consequence of Lenz's law, since there is no change in the magnetic field. A perfect diamagnet would create currents which exactly oppose any magnetic field brought near it, but it would not necessary do this spontaneous-expulsion.
Expulsion of flux is a consequence of the cooper pairs maintaining a zero ground state momentum, ie: this is the only assumption needed to derive the London Equations. Genenth also brings up a good point.
1. What is superconductivity?
Superconductivity is a phenomenon in which certain materials can conduct electricity with zero resistance when cooled below a certain temperature, called the critical temperature. This means that electric current can flow through these materials without any loss of energy, resulting in extremely efficient electrical systems.
2. How does superconductivity occur?
Superconductivity occurs when the electrons in a material pair up and move together in a coordinated manner, known as Cooper pairs. These pairs can move through the material without experiencing resistance, allowing for the zero-resistance flow of electricity.
3. What are the applications of superconductivity?
Superconductivity has many practical applications, including in MRI machines, particle accelerators, and high-speed trains. It also has potential uses in energy storage, power transmission, and quantum computing.
4. What are the challenges in achieving superconductivity at room temperature?
One of the main challenges in achieving superconductivity at room temperature is finding materials that can maintain their superconducting properties at higher temperatures. Additionally, the cost and difficulty of producing and maintaining extremely low temperatures for superconductivity to occur is a major obstacle.
5. What are the potential drawbacks of superconductivity?
One potential drawback of superconductivity is that it requires extremely cold temperatures, which can be costly and difficult to maintain. In addition, the materials used for superconductors can be expensive and may have limited availability. There is also ongoing research to understand any potential health or environmental effects of using superconductors in various applications.
  • Atomic and Condensed Matter
9K
  • Quantum Physics
  • Electrical Engineering
