Super easy driving question - instantaneous acceleration
In summary, the car's speed is increasing with time because it has an acceleration in the same direction.
physicsgurl12
184
super easy driving question -- instantaneous acceleration
a Person in a car is driving down a straight road. The instantaneous acceleration is decreasing with time but is directed in the same direction as the cars motion the speed of the car is constant or increasing with time. explain
i know its not decreasing with time.
Hi again physicsgurl12! :smile:
For this you need to understand a little bit about acceleration and speed.
The definition of acceleration is: the change in speed per unit of time.
(Similarly the definition of speed is: the change in position per unit of time.)
So if acceleration is positive, this means that the change in speed is also positive, meaning that speed increases.
Can you tell whether the acceleration is positive or negative?
If the direction of acceleration is directed in the same direction as the car's velocity than it must be positive.
If the car's acceleration is positive (greater than zero) than the velocity must be increasing per unit time, regardless if the acceleration is decreasing in terms of magnitude.
Example : Velocity starts at 10 m/s forward at t=1
Acceleration is 10 m/s^2 (same direction as velocity) at t=1s forward but decreases to 2 m/s^2 at t=2s. Speed at t=2s (new speed) will be 14 m/s instead of being 20 m/s if the acceleration was constant.
The car is still going forward and it's speed is increasing because you still have an acceleration in the same direction.
negative. because its decreasing?
Consider the speed of a skateboard.
Let's assume that the speed of the skateboard is decreasing.
Does that mean the speed is negative, or in other words that your skateboard is moving backward?
No decreasing means going from a big value to a lesser value. Going from 10 to 3 is decreasing.
Negative means less than zero. A negative acceleration would be an acceleration against the car.
If you drive a car into a building the car will stop and go backwards because the building is doing a negative acceleration relative to the car's initial trajectory.
moving backwards? because its distance and if the speed decreases it doesn't mean it has to go behind the orgin.
Uhh, right.
So when you're moving forward with a decreasing speed, you're still going forward, meaning you have a positive speed.
That is, until the speed becomes zero, after which you would be going backward.
Now back to the problem.
So your acceleration is decreasing.
Does the problem statement say in which direction the acceleration is (even though it is decreasing)?
I like Serena said:
Uhh, right.
nope it just its decraseing and opposite of the car.
Hmm, I read: "The instantaneous acceleration (is decreasing with time but) is directed in the same direction as the cars motion".
oh. just kidding. that's what i get for trying to do two at once
Sooooooo?
so then its moving the same direction as the car
Uhh? :confused:
What is moving in the same direction as the car?
the acceleration. isn't that what we were talking about?
Ahhh, well, "acceleration" isn't "moving"...
So the acceleration is in the same direction as the car.
What does that tell you about the speed of the car?
that its accelerating
Good! :shy:
Do you have the answer to your problem now?
um i feel like its constant because its decreasing acceleration even though its going the same direction as the car
Uhh... exactly what is constant?
speed?
Uh, well, we just established that the acceleration was in the direction of the motion of the car.
Since the change in speed (per unit of time) equals the acceleration, the speed cannot be constant...
okay so then the speed is increasing with time.
Guessing? :confused:
Or do you get it now?
But yes, you're right! :smile:
no i get it now. thanks.
1. What is instantaneous acceleration?
Instantaneous acceleration is the rate at which the velocity of an object changes at a specific instant in time. It is the change in velocity divided by the change in time, and is typically measured in meters per second squared (m/s^2).
2. How is instantaneous acceleration different from average acceleration?
Average acceleration is the change in velocity divided by the total time it takes for that change to occur. It is an average value over a period of time, whereas instantaneous acceleration is the value at a specific moment in time. Average acceleration can also be calculated for an entire journey, whereas instantaneous acceleration can only be calculated for a specific point.
3. What factors affect instantaneous acceleration?
The factors that affect instantaneous acceleration include the initial velocity of the object, the force acting on the object, and the mass of the object. The direction of the force also plays a role in determining the direction of the acceleration.
4. How is instantaneous acceleration measured?
Instantaneous acceleration can be measured using a variety of methods, including using a speedometer or odometer in a car, using a stopwatch and measuring the distance traveled, or using sensors and data collection tools in experiments.
5. Why is instantaneous acceleration important?
Instantaneous acceleration is important because it helps us understand how objects move and how forces affect their motion. It is also a key concept in understanding more complex concepts like velocity and acceleration graphs, and can be used in practical applications such as designing vehicles or predicting the behavior of objects in motion.
