Supercharger Pulley sizing
In summary: The gear ratio can be expressed in various ways, including: (1) the number of teeth on the smaller gear divided by the number of teeth on the larger gear; (2) the number of teeth on the smaller gear multiplied by the number of teeth on the larger gear; (3) the number of revolutions of the smaller gear divided by the number of revolutions of the larger gear; or (4) the number of revolutions of the smaller gear multiplied by the number of revolutions of the larger gear.
Stay Tuned...
Ok. So my crank pulley is 127mm o.d. which drives a supercharger pulley 73.27 mm o.d. to make 9 psi of boost.
The problem is, the supercharger puller is too small and causes the belt to rub. So i increased the supercharger pulley to 101.6 mm o.d. and now the it only makes 4.5 psi of boost (not enough)
I have someone who is going to custom make a new crank pulley, larger than the current one to compensate and make 9psi of boost, by keeping the 101.6 mm o.d. supercharger pulley
The question is, what size (o.d.) does the new crank pulley need to be, to drive the 101.6 mm o.d. supercharger pulley to make 9 psi of boost?
I took an engineering class 10 years ago and used my distant memory of gear train ratio calculations. But i got two different answers, 160.2 mm o.d. and 175.77 mm o.d. This of course made me second guess my calculations and it didn't help that my boy called me an idiot for even using the this formula:
Since- 127 : 73.27 = 9 psi [127/73.27 = 1.73] or 57.71%
Ratio- 1.73 : 1 = 9 psi
Therefore- 1.73 x 101.6 = 175.77 mm o.d.
Please advise, thx.
You are right, you just want something with the same gearing ratio. So as the orig is 1.73:1 you just want to size the crank pulley up accordingly.
I agree.
Just make sure you can get a new, longer belt that fits.
Thanks for the prompt response and confirmation.
My friend still thinks I'm wrong though...lol. He says that i should take the percentage difference between the two supercharger pulleys and then increase the crank pulley by that percentage. That doesn't seem to settle right with me since the numbers/results are different. A percentage value of a smaller number results in a different value of that same percentage of a larger number...no?
Your friend is wrong, for precisely the reason you state. Unless he means that you increase both both by the same percentage (which is eactly what you were doing). In this case each is 73% bigger.
Thank you
not to beat a dead horse, but he punched some numbers on a calculator while murmuring something about distance traveled by the pulley in the mile vs RPM and came up with 142 mm for the new crank pulley. He won't tell me what formula he used, but swears he's correct.
I am concerned because the custom machining of this crank pulley is expensive and takes 8 weeks.
Just totally ignore him, he's talking bollocks.
Pulleys are just like gears if you want one to turn at a set speed with a set input you need a set ratio.
Say with a drive of 3000rpm (engine speed) this gives a compressor RPM of 5190RPM (ish) with the 127:73 pulleys.
With a drive of 127:101 you get a compressor speed of 3772 rpm.
With the ratio of 142:101 you get a compressor speed of 4217 rpm.
If you use 175.77:101 (as you originally said) you get a compressor speed of 5190rpm . Which is the same as the original sized pulley system.You'd better tell your mate it's time to go to the library and get a basic book on gearing out.
thx again. I rest my case.
It sounds like he's confusing it with transmission or final-drive gearing. I built superchargers for several years (machinist/fabricator), and the advice here is spot-on.
What type of blower are you running? What is he charging for the pulley?
We can't be all wrong:
From http://en.wikipedia.org/wiki/Gear_ratio" :
The gear ratio is the relationship between the numbers of teeth on two gears that are meshed or two sprockets connected with a common roller chain, or the circumferences of two pulleys connected with a drive belt.
Since the number of teeth is also proportional to the circumference of the gear wheel (the bigger the wheel the more teeth it has) the gear ratio can also be expressed as the relationship between the circumferences of both wheels (where d is the diameter of the smaller wheel and D is the diameter of the larger wheel):
thanks but he stills we are wrong.. lol
problem is, we may not be able to physically fit a 175.77mm pulley in there so we'll have to see
You would be better to go to a belt manufacture like Browning (Emersion-ept) or Gates. They have engineers that do this type of thing 8 hrs/day five days a week. Also they have engineering information c/w formulas to help you.
Besides ratios you need to be concerned with small pulley size otherwise there is not enough wrap on pulley, speed max 6000 ft/min, center distance and much more.
You can go to Emersions site but need to log on, or if you live in a NA city try yellow pages under Power Transmission Equipment and talk with one of their Reps.
Your friend's logic is correct but probably did the math wrong...
if you have a 100mm:60mm pulley
upsize both by 50% you get 150mm:90mm
the ratio of 100:60 = 1.6666666
the ratio of 150:90 = 1.6666666
So changing both pullies by the same % is correct
In your case you go from
127:73.27
To
x : 101.6
101.6/73.27 = 38.66% larger
apply the same factor of 1.3866 to your crank pulley and you get
127 * 1.3866 = 176mm
Check the ratio:
127/73.27 = 1.73333:1
176/101.6 = 1.73228:1
So it's maintained (minus whatever rounding errors i made in that)
Your friend's logic is correct, his numbers are not.
The other way to look at this (which you mentioned him doing) is looking at circumference (which is what you meant by rotations / distance ...etc)
circumference = 2.pi.d
so if you scale your diamter by 50%
the circumference scales by 50%
You can translate that same change into a 50% increase in the other pulley's circumference
which translates into a 50% change in the other pulley's diameter...
Same thing
Your friend is a smart man that doesn't know how to use a calculator :) ... the concept is right, the numbers he gave you are wrong.
PS: If you need a professional pulley calculation (and other engine modifications) check out my software :
http://www.superchargerperformance.com/the-power-calculator"
1. What is a supercharger pulley and what does it do?
A supercharger pulley is a device that connects the supercharger to the engine and is responsible for driving the supercharger. It is an essential part of a supercharger system as it increases the airflow and provides more power to the engine.
2. How does the size of the supercharger pulley affect performance?
The size of the supercharger pulley affects the amount of boost that the supercharger provides to the engine. A smaller pulley will spin the supercharger faster, resulting in more boost and increased performance. On the other hand, a larger pulley will spin the supercharger slower, providing less boost and potentially decreasing performance.
3. What factors should be considered when choosing the right size supercharger pulley?
When choosing the right size supercharger pulley, it is important to consider the engine size, desired boost level, and the type of supercharger. The size of the pulley should also be matched to the rest of the components in the supercharger system to ensure optimal performance.
4. Can a smaller supercharger pulley cause any damage to the engine?
Yes, a smaller supercharger pulley can potentially cause damage to the engine if the boost levels are too high. It is important to carefully select the size of the pulley and ensure that it is compatible with the rest of the components in the supercharger system to prevent any potential damage.
5. Is it possible to change the supercharger pulley size without professional help?
While it is possible to change the supercharger pulley size on your own, it is recommended to seek professional help, especially if you are not familiar with the process. This will ensure that the pulley is installed correctly and safely, avoiding any potential damage to the engine or supercharger system.
  • Mechanical Engineering
  • General Engineering
10K
