Superheated steam and water together
In summary,The water in the bowl will be heated by the injected steam, and the pressure and temperature inside the bowl will rise. Eventually, the steam will become saturated and the process will end.
  • #36
I just forgot to add the word adiabatic.
  • #37
So, what do you think will happen to the amount of liquid water in the container if we compress the original contents of the container with a piston to the equilibrium vapor pressure of water at 23.6 C?
(a) it will increase
(b) it will remain the same
(c) it will decrease
Choose a, b, or c.
  • #38
If you want to mean that if by mechanical means, the pressure has been increased from 20C saturation level to 23.6C saturation level; then the answer is very much evident. Kindly read all the posts (especially posts by you) to any third person and ask him/her the same question and let's see the answer.
  • #39
Well, compressing it mechanically with a piston is the same as compressing it using the superheated steam (as you yourself pointed out), provided the original contents is kept separate from the injectate using a massless, frictionless, insulated piston to separate them.
So, please, refresh my memory: choose (a), (b), or (c).
I will help you check your answer using the steam tables to quantify it precisely.
  • #40
I just wanted to see what you were going to say. I think you were going to say that the amount of liquid water increases. Surprise! I tend to agree with this assessment for this particular (very wet) case in which the amount of liquid water is much, much, higher than the amount of water vapor. But we would like to quantify precisely how much the increase would be by employing the steam tables. The calculation is really simple.
You said in a previous thread that, for the adiabatic reversible compression of a steam/water mixture, the change in entropy of the mixture should be zero. So let's start out by calculating the entropy of the original mixture. At 20 C, the steam tables give values of the specific entropy of saturated liquid water and saturated water vapor as ##s_L=0.2966 kJ/kgK## and ##s_V=8.667 kJ/kgK##, respectively. Therefore, the total initial entropy of our system is given by:
$$S=(1)(0.2966)+(0.0173)(8.667)=0.4198\ kJ/K$$
This must also be the total entropy of our final saturated mixture at 23.6 C. Interpolating in the steam tables to a saturation temperature of 23.6 C, we calculate values of the specific entropy of saturated liquid water and saturated water vapor as ##s_L(23.6)=0.3477\ kJ/kgK## and ##s_V(23.6)=8.588\ kJ/kgK##. Therefore, for the mixture at 23.6 C, we have$$1.0173[0.3477+(8.855-0.3477)x]=0.4198\ kJ/K$$where x is the final mass fraction of water vapor. Solving for x yields x = 0.00764. So, the final mass of saturated liquid water at 23.6 C is 1.0095 gm. Thus, the mass of liquid water increases by 9.5 grams; and the mass of water vapor decreases by 9.5 grams to 7.8 grams. This compares with the 6 gm increase that is obtained when we inject 10 gm of superheated steam at 60 C into the tank.
  • #41
I haven't said that. I just want to consider this for the sake of simplicity. And can you tell me how the amount of water can be a factor here. I mean if the amount of water is sufficiently high and more than the amount of steam, then amount of water will increase and will decrease if the case is reverse.
One simple explanation is that, if case of lesser amount of water, additional heat generated by the inefficiency of the process will evaporate it. That can certainly happen in reality. But, at least we both are agreed now on one point that if the amount of water is sufficient, then the steam will remain saturated during the process of compression. Even if the compression is adiabatic. Right?
  • #42
Yes, as long as the initial wetness is greater than about 50%.
  • #43
Do you mean that if the amount of water is more than the amount of steam, then the steam will remain saturated during the compression process? I hope this is what you want to mean by initial wetness, right?
  • #44
Yes. Also, even if it's not more, it will still stay saturated if you limit the amount of compression.
  • #45
In that case, what should be the limit of compression ratio?
  • #46
It depends of the fraction of liquid water. To find that out, it is easiest to use the temperature-entropy diagram or the enthalpy-pressure diagram.
Incidentally,
You're welcome.
  • #47
Can you guess some limit?
  • #48
There are a lot of factors involved. Can you provide a specific initial state?
  • #49
Lets start with our old initial states i.e. saturated steam at 20C and 2.536 kPa.
  • #50
I'll check the Mech_Engineer's T-S diagram, and get back with you.
  • #51
How the compression limit can be determined by the T-S diagram?
  • #52
You move up a constant entropy line until you hit the 100% dry envelope. You determine the temperature at that point. Then you determine the corresponding saturation vapor pressure, and take the ratio. For a temperature higher than that, the compressed gas would be superheated (i.e., beyond your desired limit).
  • #53
If the amount of water increases with pressure, then how can we hit the 100% dry envelope?
  • #54
The amount of liquid water increases with pressure if there isn't enough liquid water around to start with. Mech_Engineer showed this (i.e., if it's pretty wet to start with). Otherwise, the mixture will become drier as you compress. So the amount of water increasing or decreasing depends on the initial wetness. Check out the T-S diagram.
  • #55
That's contrary to what you have said in post 42.
  • #56
I'm going to try to say this as clearly as I can.
1. If the initial mixture is low enough quality (high wetness), the amount of liquid increases as you compress the mixture no matter how much you compress.
2. If the initial mixture is high quality (low wetness), the amount of liquid decreases as you compress the mixture, and the mixture can reach 100% dryness (if you compress it enough). But, if you don't compress it the necessary amount, you will still have some liquid left over in the end.
3. There is a cross over in these two kinds of behavior at an initial quality in the 40 - 60 % range (depending on the starting temperature/pressure).
I strongly urge you to spend time examining the temperature entropy diagram for water so that you can see for yourself how this all works out.
  • #57
Thanks! Though the actual scenario isn't much clear. Whatsoever, at least it can be said that with sufficient water, the steam will remain saturated during the compression process and part of it will be added to the water to increase the enthalpy of water to reach to saturation level of higher temperature. In such case, power needed to compress that steam will be less as it will remain saturated and power needed to compress steam will be least if the steam can be preserved at saturated state during the process.
  • #58
Well, the amount of water can be calculated if we consider that the amount of steam will be mixed with water sufficient amount of water so that all the latent heat of steam will add to the final volume and raise its temperature and pressure. As for example, if we take 1 kg steam at 20C and have to mix it with water by pressurisation so that the latent heat of the steam will be contained in the final volume of water, then we will need 32 kg of water for that.
  • #59
Let's discuss this matter from another point of view. What will happen if instead of compressing the steam, the water will be heated (consider the whole system to be totally insulated). First small amount of steam will rise from the water and this will add to the amount of steam inside and thus increasing the pressure and temperature inside and at the same time the boiling point of the water will increase too. In short, the boiling point of the water increases along with the pressure and temperature inside and at the same time both water and steam will remain in saturated state.
In fact, what I have said above is the principle behind heat pipe, which are well tested and now is even used in space too.
  • #60
Boiler ? As in what supplies steam to a steam engine ?
  • #61
Can't understand what you want to mean be "Boiler". Though in sense you can say that if the Boiler is supposed to supply saturated steam instead of superheated steam.
Though this process is basically different from Boilers in one point. In Boilers, the heating is isobaric i.e. the pressure remains constant while the temperature increases. But, in this process, the volume remains constant and both the temperature and pressure increase.
  • Mechanical Engineering
13K
  • Thermodynamics
  • General Engineering
