Superposing two metrics
  1. Aug 26, 2011 #1
    Hi. I can't find a source that shows how to superpose two metrics.
    For example, superposing Schwarzchild metric
    [itex]ds^2=\left(1-\frac{2M}{r}\right)dt^2-\frac{dr^2}{1-\frac{2M}{r}}-r^2d\Omega^2[/itex]
    with de Sitter metric
    [itex]ds^2=\left(1-\frac{r^2}{\alpha^2}\right)dt^2-\frac{dr^2}{1-\frac{r^2}{\alpha^2}}-r^2d\Omega^2[/itex]​
    yields de Sitter-Schwarzchild metric
    [itex]ds^2=\left(1-\frac{2M}{r}-\frac{r^2}{\alpha^2}\right)dt^2-\frac{dr^2}{1-\frac{2M}{r}-\frac{r^2}{\alpha^2}}-r^2d\Omega^2[/itex]​
    I've tried letting
    [itex]g_{\mu\nu}=g_{\mu\nu}\left(Schwarzchild\right)+g_{\mu\nu}\left(de Sitter\right)-\eta_{\mu\nu}[/itex]​
    which works for the time component of the metric but not the radial. Any ideas?
  3. Aug 26, 2011 #2
    WannabeNewton
    Can you even add them like that? The solutions aren't linear.
  4. Aug 26, 2011 #3
    I'm pretty sure you can - you're just adding matrices.
  5. Aug 26, 2011 #4
    WannabeNewton
    No what I mean is that linear superpositions of two metrics won't result in another solution to the EFEs so why do you want to add them like that.
  6. Aug 26, 2011 #5
    I didn't know that. I'm basically stuck as to how to superpose the two metric spaces. Maybe the answer is obvious and I'm being thick.
  7. Aug 26, 2011 #6
    WannabeNewton
    It isn't easy to properly superpose two metrics. Unlike electric fields under maxwell's equations, which linearly superpose, in GR two interacting gravitational fields present a much, much more complicated interaction (release of gravitational waves etc.) because the gravitational field is coupled to itself. You can simply add the two matrices, sure, but that won't give you anything physically relevant; combining two metrics is non - trivial. There is a linearized form of the EFEs under which linear superposition does result in another solution but the linearized EFEs are only valid for weak fields (like low amplitude gravitational waves in vacuum).
  8. Aug 26, 2011 #7
    OK, thanks very much for that.
Loading...
