Nick R
- 70
Hello, I am brand new to this stuff and am trying to get my head around it all. I've spent considerable time trying to understand this from Landau's book on the subject (chapter 1 of course).
I bet I'd get more answers by being more brief but I always find that asking the problem carefully sometimes helps me understand the problem better.
A wavefunction, which completely describes the states of a quantum object, can be decomposed in terms of its eigenfunctions,
[tex]\psi = \sum_{n} a_{n}\psi_{n}[/tex]
Eigenvalues (maybe a physical quantity) correspond to the eigenfunctions by
[tex]\widehat{f}\psi_{n} = f_{n}\psi_{n}[/tex]
Where [tex]\widehat{f}[/tex] is the operator that corresponds to the quantity in question.
From this, we see that the value of [tex] a_{n}[/tex] for a given eigenfunction in the decomposition is (somehow) related to the "probability" that the physical quantity [tex]f[/tex] has the value [tex]f_{n}[/tex].
Given, is
[tex]\int |\psi_{n}(q)|^{2}dq = 1[/tex]
and
[tex]\int |\psi(q)|^{2}dq = 1[/tex]
How does it follow that [tex]|a_{n}|^{2}[/tex] is the probability of the physical quantity [tex]f[/tex] having the value [tex]f_{n}[/tex]? The reasoning presented in the book is not clear to me - it is a sort of deductive reasoning that seems like guesswork.
Of course if this is a probability then,
[tex]\sum |a_{n}|^{2} = 1[/tex]
I don't understand how this follows from the other things.
Here is why I am having a problem with this:
I can see it all works if the following is true:
[tex]\psi = a_{0}\psi_{0} + a_{1}\psi_{1} + ... + a_{n}\psi_{n}[/tex]
[tex]|\psi| = \sqrt{|a_{0}\psi_{0}|^{2} + |a_{1}\psi_{1}|^{2} + ... + |a_{n}\psi_{n}|^{2}}[/tex]
[tex]\int |\psi|^{2}dq = \int |a_{0}\psi_{0}|^{2}dq + \int |a_{1}\psi_{1}|^{2}dq + ... + \int |a_{n}\psi_{n}|^{2}dq[/tex]
[tex] = |a_{0}|^{2}\int |\psi_{0}|^{2}dq + |a_{1}|^{2}\int |\psi_{1}|^{2}dq + ... + |a_{n}|^{2}\int |\psi_{n}|^{2}dq[/tex]
Truth of this rests on the truth of two identities for complex numbers.
[tex]|(a+bi)(c+di)|^{2} = |a+bi|^{2}|c+di|^{2} IDENTITY ONE[/tex]
According to my calculations this is true.
[tex]|(a+c) + (b+d)i|^{2} = |a+bi|^{2} + |c+di|^{2} IDENTITY TWO[/tex]
According to my calculations this is false, unless there is a constraint [tex]2ac = -2bd[/tex].
What is going on here? Is there some sort of constraint?
Given, is
and
