Superposition / Wave Question
In summary, the astronauts on Planet X have a 2.50m-long string with a mass of 4.60g. They stretch it horizontally over a pulley 1.50m away and hang a 1.70kg mass on the free end. Standing waves on the string exist at frequencies of 64Hz and 80Hz. Using the formula v² = T/µ, the gravitational pull of Planet X can be calculated by finding the wave speed and rearranging the formula to solve for the gravitational pull. The final answer for g, the acceleration due to gravity on Planet X, is 2.49m/s^2.
momogiri
52
Question
Astronauts visiting Planet X have a 2.50m-long string whose mass is 4.60g. They tie the string to a support, stretch it horizontally over a pulley 1.50m away, and hang a 1.70kg mass on the free end. Then the astronauts begin to excite standing waves on the string. Their data show that standing waves exist at frequencies of 64Hz and 80Hz, but at no frequencies in between.
What is the value of g, the acceleration due to gravity, on Planet X?
Attempt
No idea. At all. I tried a bunch of numbers and they're not right XD
Can someone explain how to get it please? :D
Hi Momogiri,
Firstly let's look at a way to approach this problem. We know that we have a 2.50m long string with mass 4.60g. We are told that it is stretched 1.50m and a mass of 1.70 kg is on the free end. We also know that 2 standing waves exist at frequencies 64 Hz and 80 Hz. We know that this string is under a certain tension and that is:
1.70 kg x gravitational pull of planet X
From this it is clear that we must use the formula v² = T/µ which can be rewritten as:
v² = mass * gravitational pull/µ
We can easily find µ since both the length and the mass of the rope are given to us. We also need to make use of another formula to find which node (m) we are dealing with. We know that :
v = 2Lf / m and that the wave speed is the same in both cases therefore:
2Lf₁/ m = 2Lf₂/ (m+1)
After solving for v you can then solve for the gravitational pull of planet X by rearranging v² = mass * gravitational pull/µ. Hope this was helpful,
Cheers,
Sinan
Wow, thanks Sinan! That really helps!
For future reference, the answer was 2.49m/s^2
1. What is superposition?
Superposition is a principle in physics that states that when two or more waves intersect, their amplitudes combine to form a new wave.
2. How does superposition relate to quantum mechanics?
In quantum mechanics, superposition refers to the ability of a particle to exist in multiple states or locations at the same time. This is a fundamental concept in quantum mechanics and helps explain the behavior of subatomic particles.
3. Can superposition be observed in everyday life?
Yes, superposition can be observed in everyday life through phenomena such as interference patterns in water waves, sound waves, and light waves. It is also used in technologies like MRI machines and computer processors.
4. What is the difference between constructive and destructive interference?
Constructive interference occurs when two waves combine to form a wave with a larger amplitude, whereas destructive interference occurs when two waves cancel each other out, resulting in a wave with a smaller amplitude or no wave at all.
5. How is superposition used in the field of quantum computing?
In quantum computing, superposition allows for the creation of qubits, which can exist in multiple states at the same time. This allows for more complex and faster calculations compared to traditional computing methods.
