Solve Supersymmetry n=8: Degrees of Freedom for Supergravity
In summary, supersymmetry is a theoretical framework that proposes a symmetry between fermions and bosons in order to explain unsolved problems in physics. N=8 refers to the maximum number of supersymmetry generators in a four-dimensional theory, which is significant because it corresponds to the maximal supergravity theory. Degrees of freedom and supersymmetry are related, with the number of supersymmetry generators determining the degrees of freedom in a theory. Solving supersymmetry n=8 involves complex mathematical calculations and could have implications for our understanding of fundamental laws of physics and have practical applications.
cuerdero
Someone can helpme finding the number of degree of freedom for supergravity n=8?
N=8 supergravity has exactly the same degree of freedom as N=4 Yang-Mills.
The maximal number of supersymmetry generators possible is 32. Theories with more than 32 supersymmetry generators automatically have massless fields with spin greater than 2. It is not known how to make massless fields with spin greater than two interact, so the maximal number of supersymmetry generators considered is 32. This corresponds to an N = 8 supersymmetry theory. Theories with 32 supersymmetries automatically have a graviton.
1. What is supersymmetry and why is it important in physics?
Supersymmetry is a proposed theoretical framework that suggests the existence of a symmetry between fermions (particles with half-integer spin) and bosons (particles with integer spin). This symmetry could potentially explain several unsolved problems in physics, such as the hierarchy problem and the nature of dark matter.
2. What is n=8 in supersymmetry and why is it significant?
In supersymmetry, n refers to the number of supersymmetry generators, which are mathematical objects that describe the symmetry between fermions and bosons. In the case of n=8, this means that there are 8 supersymmetry generators, making it the maximum number possible in a four-dimensional theory. This specific value is significant because it corresponds to the highest possible degree of freedom for a supersymmetric theory, known as the maximal supergravity theory.
3. What are degrees of freedom and how are they related to supersymmetry?
Degrees of freedom refer to the number of independent variables that are needed to describe a physical system. In supersymmetry, the degrees of freedom for a theory can be determined by the number of supersymmetry generators. For example, the maximal supergravity theory with n=8 has 128 degrees of freedom, which is the highest possible for a supersymmetric theory in four dimensions.
4. How can supersymmetry n=8 be solved?
Solving supersymmetry n=8 involves finding a mathematical framework that satisfies all the necessary conditions and equations for the theory to be consistent and predictive. This involves complex mathematical calculations and is an ongoing area of research in theoretical physics.
5. What are the implications of solving supersymmetry n=8?
If supersymmetry n=8 is successfully solved, it could provide a deeper understanding of the fundamental laws of physics and potentially lead to the discovery of new particles and phenomena. It could also have practical applications in areas such as cosmology and high-energy physics.
  • Beyond the Standard Models
  • Science and Math Textbooks
