Supremum and infimum of a set
  • Thread starter Felafel
Felafel
171
Hello everyone,
I found this exercise on the internet:
find the supremum and infimum of the following set A1, where
A1 = {2(-1)^(n+1)+(-1)^((n^2+n)/2)(2+3/n): n belongs to |N*}
being |N* = |N\{0}
The solution was:
A1 = {-3, -11/2, 5}U{3/4k, -3/(4k+1),-4-3/(4k+2),4+3/(4k+3) : k belongs to |N*}
I don't get the reasoning behind. what's k? why and how did they use it?
Answers and Replies
Felafel
171
It would help us a lot if you would use this to make your post more readable.
ok, here i go:
[itex]A1 = {2(-1)^{n+1} + (-1)^{(\frac{n^2+n}{2})} ( 2+ \frac{3}{n}): n \in \mathbb{N}*}[/itex]
being [itex] \mathbb{N}^{*} = \mathbb{N} \setminus \Big\{0\Big\} [/itex]
The solution was:
[itex]A1 = \Big\{-3,\frac{-11}{2}, 5\Big\} \cup \Big\{\frac{3}{4k}, \frac{-3}{4k+1},-4- \frac{3}{4k+2},4+ \frac{2}{4k+3}\Big\} : k \in \mathbb{N} [/itex]
what's the reasoning behind this solution? why using the k?
micromass
Staff Emeritus
Insights Author
22,178
3,305
That solution doesn't really make any sense. You are asked to give two values, the infimum and the supremum. I don't understand why the solution would give that as answer...
Felafel
171
According to the text, thanks to this proceeding you prove that:
[itex] inf A1= - \frac{11}{2}, supA1=5 [/itex]
(even knowing it still doesn't help me to understand how they solved that)
Felafel
171
sorry, didn't know latex didn't work on quick replies.
here i go again:
micromass
Staff Emeritus
Insights Author
22,178
3,305
Ah, now it makes sense. What they essentially do is write that A1 in another form. Why did they do that? Well because that other form makes it easier to see what the infimum and the supremum actually is.
Now, do you understand that the other form of A1 is equal to your original set?? That would be the first thing you might want to figure out.
Felafel
171
no, i don't get how the set was manipulated :(
micromass
Staff Emeritus
Insights Author
22,178
3,305
The idea is that things like [itex](-1)^{n+1}[/itex] and [itex](-1)^{(n^2+n)/2}[/itex] are annoying expressions. They are either 1 or -1. Can you find conditions on n on when the result is 1 and when it is -1??
Let me do the first: [itex](-1)^{n+1}[/itex] is 1 if n+1 is even and is -1 if n+1 is odd. So we get the following result
[tex]2(-1)^{n+1}+(-1)^{(n^2+n)/2}(2+\frac{3}{n})=\left\{\begin{array}{ll} 2+(-1)^{(n^2+n)/2}(2+\frac{3}{n}) & \text{if n is odd}\\ -2 + (-1)^{(n^2+n)/2}(2+\frac{3}{n}) & \text{if n is even}\end{array}\right.[/tex]
Can you do a similar thing to get rid of the [itex](-1)^{(n^2+n)/2}[/itex]?
Felafel
171
thankss, much clearer now :)
Suggested for: Supremum and infimum of a set
  • Last Post
  • Last Post
  • Last Post
