Skeletor
- 1
HELP! PLease cna someone explain how to do this quck please?!
----- + (root3+1)squared
root3+1
root3+1
The equation being solved is 1 + (root3+1)^2/root3+1.
The value of root3+1 is approximately 2.73205.
To simplify the equation, you can first expand the numerator using the FOIL method (First, Outer, Inner, Last). Then, combine like terms and simplify the fraction.
The final answer is 4 + 2*root3.
You can check your answer by plugging it back into the original equation and simplifying. If you get the same value on both sides of the equation, then your answer is correct.
