Surface area and volume of a cylinder
In summary: Thank you for your help.In summary, the surface area and volume of a pressure vessel in the form of a cylinder with each end in the form of a hemisphere, with an overall length of 12 meters and a diameter of 3 meters, would be 113.04 m^2 and 77.715 m^3 respectively. However, the length of the cylinder should be 9 meters instead of 12 meters, resulting in a corrected surface area of 127.17 m^2. It is also important to note that the ends of the cylinder should not be included in the surface area calculation as they do not contribute any surface area.
scientist
28
Could a tutor please check my work?
question:
What is the surface area and volume of a pressure vessel in the form of a cylinder with each end in the form of a hemisphere, if the overall length is 12 meters and the diameter is 3 meters.
solution:
given:
radius = 1.5m
diameter = 3m
height or length = 12m
pi=3.14
Total surface area of a cylinder = 2*pi*r*h + 2*pi*r^2
TSA = 2*3.14*1.5*12 + 2*3.14*1.5^2
= 113.04 m^2 + 14.13 m^2
= 127.17 m^2
Volume of a cylinder = pi* r^2*h
V= 3.14*1.5^2*12
= 84.8 m^3
Is this correct?
Mathematics news on Phys.org
Overall length is 12m, and that includes the two radii of the hemispheric ends. So why are you assuming that the the height of the cylindrical portion is 12m?
Second problem : the surface area of the object is the surface area of the *wall* of the cylindrical portion *plus* the combined surface areas of the two hemispherical portions. You should not include the areas of the discs that make up a closed cylinder (like you did). And you did not consider the S.A. of the hemispherical ends at all.
Third problem : volume of the cylinder is certainly correct, but what about volumes of the hemispherical ends?
To: Curious3141
The height of the cylinder is 12 meters high. The length and the height are the same thing. Both are 12 meters.
The volume of the hemispherical ends = 2*pi*r^3 / 3.
V=2*3.14*1.5^3 / 3
= 21.195 / 3
= 7.065 m^3 at each end.
The total surface area of the hemispherical ends = 4*pi*r^2 / 2
TSA = 4*3.14*1.5^2 / 2
= 28.26 / 2
= 14.13 m^2 for both ends.
= 127.17 m^2
127.17 m^2 - 14.13 m^2 = 113.1 m^2 total surface area of the cylinder.
Can you check my work again?
From,
scientist
In your first post you said "the overall length is 12 meters" which would include the two hemispheres. Now you say "The height of the cylinder is 12 meters" which does not include the two hemispheres.
Which is it?
Why do you calclulate the volume of one hemisphere as [itex]\frac{2}{3}\pi r^3[/itex], then turn around a calculate the volume of both as [itex]\frac{4}{3}\pi r^3[/itex]? They are both correct but you don't use the first one!
Curious3141 told you NOT to include the are of the ends of the cylinder- that is not part of the surface area of the pressure vessel. So you include it and then subtract it off?? (It's interesting that you get 3.04 for the lateral area of the cylinder, add the area of the two end circles, then immediately subtract off that area and get an answer of 3.1!)
Oh, and you never do calculate the whole surface area of the vessel.
The crucial point is whether the overall length is 12 m or only the length of the cylinder. Exactly what does your problem say?
Ok, let's get the height straightened out first. HallsofIvy asked:
The crucial point is whether the overall length is 12 m or only the length of the cylinder. Exactly what does your problem say? The problem in my book says the overall length is 12 meters. So there is only one number left for the height. And that is 3 meters, for the height.
scientist
VOLUME:
volume of the ends = 4*3.14*r^3 / 3 = 4*3.14*1.5 m^3 / 3 = 14.13 m^3
14.13m^3 / 2 = 7.065 m^3 at each end.
volume of cylinder = 3.14*r^2*h = 3.14*1.5^2*12m = 84.78m^3
volume total = 84.78m^3 - 7.065m^3 = 77.715m^3
SURFACE AREA:
surface area of the ends = 4*3.14*1.5m^2 = 28.26m^2 / 2 = 14.13m^2 at each end.
surface area of the cylinder = 2*3.14*r^2 + 2*3.14*r*L = 2*3.14*1.5m^2 + 2*3.14*1.5m*12m = 127.17m^2
surface area total = 127.17 m^2 - 14.13 m^2 = 113.04 m^2
scientist
For the height of what? The hemispheres have diameter 3 m so the two of them add 3 m to the overall length. The length of the cylinder is 12- 3= 9 meters.
scientist said:
VOLUME:
Yes, that is correct. (Except that it is not "at each end"- that is the total volume of both ends.)
NO! since the "overall length" is 12 m and the hemispheres account for 3 m of that, the length of the cylinder is 9 m, not 12! That's what we've been trying to tell you all along!
SURFACE AREA:
Well, not at "each end"- that's the total area of both ends.
One more time and then I give up! The ends of the cylinder are NOT part of the surface- they contribute NO surface area! Oh, and the length of the cylinder is 9 m, not 12 m.
Why in the world are you subtracting the surface area of the hemispheres?
OK, the length is 9m NOT 12m. I understand that now. I have more of these type of questions. I will practice.
1. What is the formula for calculating the surface area of a cylinder?
The formula for calculating the surface area of a cylinder is 2πr(r+h), where r is the radius of the circular base and h is the height of the cylinder.
2. How is the volume of a cylinder calculated?
The volume of a cylinder is calculated using the formula πr^2h, where r is the radius of the circular base and h is the height of the cylinder.
3. How is the surface area of a cylinder different from the lateral area?
The surface area of a cylinder includes the area of both the circular bases and the curved surface, while the lateral area only includes the area of the curved surface.
4. Can the surface area of a cylinder be greater than its volume?
No, the surface area of a cylinder cannot be greater than its volume. This is because the volume of a cylinder is determined by the height and the area of the circular base, while the surface area takes into account the curved surface in addition to the circular bases.
5. How are the surface area and volume of a cylinder related?
The surface area and volume of a cylinder are directly proportional. This means that as the surface area increases, the volume also increases, and vice versa. This relationship can be seen in the formulas for surface area and volume, where both involve the radius and height of the cylinder.
  • General Math
  • Thermodynamics
