Homework Help: Surface integral problem.
  1. Dec 6, 2012 #1
    Consider the surface S formed by rotating the graph of y = f(x) around the x-axis between x = a and x = b. Assume that f(x) ≥ 0 for axb. Show that the surface area of S is 2π times integral of f(x)sqrt(1 + f ' (x)^2) dx from a to b.
    http://i.imgur.com/qFeGP.png
    2. Relevant equations
    The integral of the magnitude of the cross product of the partial derivatives of parameterization vector, r = r(s,t). The region is R.
    3. The attempt at a solution
    I tried parameterizing the surface with parameters of x and f(x). The surface I set as g(x,f(x)). But when I took the cross product of that thing, I ended up with a useless statement involving partial derivatives which does not lead to the solution.
  3. Dec 7, 2012 #2
    haruspex
    That's not an equation. Can you elaborate?
    Please post details of you working.
  4. Dec 7, 2012 #3
    tiny-tim
    hi countzander! :smile:
    why so complicated? :cry:
    just use trig! :smile:
    (and f' = tan)
  5. Dec 7, 2012 #4
    http://i52.photobucket.com/albums/g12/countzander/Untitled-1.png [Broken]
  6. Dec 7, 2012 #5
    LCKurtz
    That isn't two parameters. ##x## is free to use as a parameter but then ##f(x)## is determined. You need another parameter if you want to do it that way. I would suggest ##\theta##, the angle of rotation as the second parameter. Express your surface as$$
    \vec R(x,\theta) = \langle x, ?, ?\rangle$$where the question marks are the appropriate expressions for ##y## and ##z## in terms of ##x,\, f(x),\, \theta##.
