Is There an Equivalent Expression to ∫ f·dr for Surface Integral?
In summary: Thus the surface integral can be written as ∬ f·d2S = ∬ f(r(s, t)) · (∂r/∂s)x(∂r/∂t) ds dt. So, yes, there is an analogous expression to ∫ f·dr for surface integrals, but it involves the cross product of the partial derivatives of the position vector.
Jhenrique
685
The line integral can be expressed, at least, in this three different ways: [tex]\int \vec{f} \cdot \hat{t} ds = \int \vec{f} \cdot d\vec{s} = \int \vec{f} \cdot d\vec{r}[/tex] The surface integral too (except by least expression above): [tex]\iint \vec{f} \cdot \hat{n} d^2S = \iint \vec{f} \cdot d^2\vec{S}[/tex] My ask is: exist some equivalent/analogous expression to ∫ f·dr for surface integral? In other words, is possible to write the surface integral in terms of the position vector r? Maybe: ##\iint \vec{f} \cdot d^2\vec{r}## ?
I don't really agree with the third formula you used for the line integral. The second one is definitely correct, the line integral takes the component of the vector field parallel to the line itself. The third one is not always valid. It is true in the case of radial motion, when you path is actually parallel to the position vector itself.
Great observation! But, are you sure? I already saw the 3rd definition a lot times.
https://en.wikipedia.org/wiki/Line_integral
If you look at the Wikipedia page you linked it says that r(t) is a bijective parametrization of the curve, not the position vector. It's just a confusing notation, that why one usually uses s(t).Inviato dal mio iPhone utilizzando Physics Forums
r(t) doesn't have to be the position vector, the Wikipedia page is saying it can be more general, but it CAN be the position vector. For a line integral, you want the differential to be a vector parallel to the curve whose magnitude is the line element, and that's exactly what dr is. Equivalently, one can write dr = (dr/dt) dt.
For the surface integral, you want the differential to be a vector orthogonal to the surface whose magnitude is equal to the element of surface area. Suppose the surface is described by giving the position vector as a function of two variables, r(s, t). Then the differential is the vector d2S = (∂r/∂s) x (∂r/∂t) ds dt.
What is a surface integral?
A surface integral is a mathematical concept that involves calculating the sum of a function over a two-dimensional surface in three-dimensional space. It is used in various fields such as physics, engineering, and mathematics to solve problems involving surfaces.
What is the difference between a surface integral and a line integral?
The main difference between a surface integral and a line integral is the dimension of the object being integrated over. A surface integral is used to calculate the sum of a function over a two-dimensional surface, while a line integral is used to calculate the sum of a function over a one-dimensional curve.
How is a surface integral calculated?
A surface integral is calculated by dividing the surface into small, infinitesimal areas, and then taking the sum of the function values at each of these areas. This sum is then multiplied by the area of each small region and then summed over the entire surface. This process is known as integration and can be done using various mathematical techniques such as the Riemann sum or the Gauss-Legendre quadrature.
What are some real-life applications of surface integrals?
Surface integrals have various real-life applications, such as calculating the flow of a fluid over a surface, calculating the mass of an object with a varying density, and determining the total electric flux through a closed surface due to an electric field. They are also used in computer graphics to render three-dimensional objects and in geophysics to model the Earth's surface.
What are the different types of surface integrals?
There are two main types of surface integrals: the surface integral of the first kind, also known as the flux integral, and the surface integral of the second kind, also known as the area integral. The former is used to calculate the flow of a vector field through a surface, while the latter is used to calculate the total area of a surface.
  • Calculus
