Surface Integrals
fibonacci101
Prove that [tex]\int\int_{S} n dS = 0 [/tex] for any closed surface S.
I used divergence theorem. But i thought it is applicable only if there is another vector multiplied to that outward unit vector (n).
[tex]\int\int_{S} F {\cdot} n dS[/tex]
Answers and Replies
Dick
26,263
619
The integral of ndS is a vector equation. Split it into components. n=(nx,ny,nz). What's a vector field F that might have the property that F.n=nx, for example?
fibonacci101
my problem is how do I show that the [tex]\int\int_{S} n dS = 0[/tex]
----> I used the divergence theorem, but I don't think it will help me 'cause it is applicable for
[tex]\int\int_{S} F{ \cdot} n dS [/tex]
not for
[tex]\int\int_{S} n dS [/tex]
Dick
26,263
619
You basically just reposted the same thing. Look, if you show integral of nx*dS, ny*dS and nz*dS are zero, you are done right? What's an appropriate choice of F for each?
fibonacci101
Is there a value of n(outward unit vector)????
Dick
26,263
619
No, n is the outward unit vector. Whatever that is. You don't have much control over that. You can choose F. Suppose you choose F=(1,0,0). What do you conclude?
fibonacci101
Yeah, I get what you are saying... So If I choose an F a vector the solution will lead to Divergence Theorem??? Am I right???
Dick
26,263
619
You can use the divergence theorem to conclude something, yes. But what do you conclude?
fibonacci101
I will conclude that [tex]\int\int_{S} F \cdot n dS = 0 [/tex]
Dick
26,263
619
Why do you conclude that and what is F.n and how does that help you conclude integral ndS is zero? You really aren't giving me much to go on except repeating the divergence theorem over and over again. You have to apply the divergence theorem in a specific way to solve a problem.
fibonacci101
[tex]\vec{n}=(\vec{i}\cdot\vec{n})\vec{i}+(\vec{j}\cdot \vec{n})\vec{j}+(\vec{k}\cdot\vec{n})\vec{k}[/tex]
Then,
[tex]\int\int_{S}\vec{n}dS=\int\int_{S}(\vec{i}\cdot\vec{n})dS\vec{i}+\int\int_{S}(\vec{j}\cdot\vec{n})dS\vec{j}+\int\int _{S}(\vec{k}\cdot\vec{n})dS\vec{k}[/tex]
I stacked to this step...
Dick
26,263
619
Then,
Now that's GOOD! You've got it. Ok, so what does the divergence theorem tell you about the first term where F=i? You may have known this all along. But I just couldn't figure out if you did from your posts.
fibonacci101
Divergence Theorem said that
[tex]\int\int_{S} \vec{F} \cdot \vec{n} dS = \int\int\int_{V} \nabla \cdot \vec{F} dV [/tex]
Dick
26,263
619
You did it again. You just quoted the divergence theorem. What DO YOU CONCLUDE from the divergence theorem? What's F and what's div(F)?
fibonacci101
[tex]div F = \left[\frac{\partial}{x}\vector{i} + \frac{\partial}{y}\vector{j}+\frac{\partial}{z}\vector{k}\right]\left(\vector{i} + \vector {j} +\vector{k}\right) [/tex]
[tex]div F =\left[\frac{\partial}{x}\vector{0} + \frac{\partial}{y}\vector{0}+\frac{\partial}{z}\vector{0}\right][/tex]
[tex]div F = 0 + 0 + 0[/tex]
[tex]div F = 0 [/tex]
Is this right??? I hope so...
ideasrule
2,271
Yes, kind of. [tex]
[/tex] should be [tex]
div F = \left[\frac{\partial}{x}\vector{i} + \frac{\partial}{y}\vector{i}+\frac{\partial}{z}\vector{i}\right]\left(\vector{i} + \vector {j} +\vector{k}\right)
[/tex] since F=i, and your next line is not correct since i is not equal to 0. However, it is true that div F=0. What do you conclude from that?
fibonacci101
Yes. So what do you conclude from div F=0?
Yeah.. That is 0...
Thanks for helping and guiding me,Sir.
Hope to guide me in my further studies..
Thanks again... I LOVE YOU!!! LOL
Dick
26,263
619
The argument looks a little strange. What is the F you are talking about? If F=i then Fx=1, Fy=0 and Fz=0. So sure, div(F)=d/dx(Fx)+d/dy(Fy)+d/dz(Fz)=0. All of the terms are zero.
fibonacci101
Is this for me????
fibonacci101
Yes, kind of. [tex]
By the definition of divergence...see??
Dick
26,263
619
Is this for me????
Yes. Divergence is a scalar, not a vector. Your derivation just looks weird.
fibonacci101
[tex]
div F = \left[\frac{\partial}{x}\vector{i} + \frac{\partial}{y}\vector{j}+\frac{\partial}{z}\vector{k}\right]\left(\vector{ni} + \vector {nj} +\vector{nk}\right) = 0
[/tex]
right???
Dick
26,263
619
[tex]
[/tex]
right???
If F=i then Fx=1, Fy=0 and Fz=0. So sure, div(F)=d/dx(Fx)+d/dy(Fy)+d/dz(Fz)=0. I know I'm repeating myself here but I don't see how what you are doing is related to div(F).
fibonacci101
So, How is it to be equal to zero???
i don't know what to do. I thought I've already got the right solution. but it is quite wrong...
Dick
26,263
619
It is zero. What's the definition of divergence? How can you say div(i), div(j) and div(k)=0. This is really pretty simple. I don't know why you are making this look so difficult.
fibonacci101
Okay!
This is my last try and I hope I will be right ..
Given a closed Surface S, the vector Area of this is zero. so that is i.t.
Dick
26,263
619
You solved it in post 11. div(i)=0, div(j)=0 and div(k)=0. Put those in for F. Not all at once, one at a time. You were all done.
Suggested for: Surface Integrals
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
