TriTertButoxy
- 194
Ok, so here's the problem:
Two circular wire hoops of radius [itex]R[/itex] are spaced a distance [itex]2\ell[/itex] apart. Consider a soap film stretching beatween the two hoops. Due to surface tension the film's equlibrium form is a surface of minimal area. Use the calculus of variations to find this minimal surface.
What happens when [itex]\ell/R[/itex] is small? What happens when [itex]\ell/R[/itex] becomes large? Is there a critical value of [itex]\ell/R[/itex]? If so, explain why; find in numerically; and say what happens when one exceeds it.
Calculus of Variations is simple: To "optimize" a quantity, [itex]y(x)[/itex], (i.e. find its minima/maxima), you find the value of [itex]x[/itex] which satisfies [itex]y'(x)=0[/itex].
If the independent is a function which optimizes a quantity (as in the case of this problem),
Here's what I did. It makes most sense to set this problem in cylindrical coordinates. So, the surface area of the soap film is given by
Here, we are assuming that there is no angular dependence of [itex]r[/itex]. So in anticipation of applying the calculus of variations (Euler's Equation), I evaluated the following quantities for [itex]F(r(z),\,r'(z);\,z)=r(z)\sqrt{1+r'(z)^2}[/itex]:
Therefore Euler's equation becomes,
I have no clue how to approach this. Mathematica gave me some really weird ugly answer, which when I asked it to FullSimplify, gave an unmanagable expression with hyperbolic sines and cosines. What's the solution to this differential equation, and how do I analytically apply the boundary conditions?
[tex]A=\int F(y(x),\,y'(x);\,x)\,dx[/tex]
the optimized [itex]y(x)[/itex] is given by the solution to the differential equation below (Euler's Equation):[tex]\frac{\partial F}{\partial y}-\frac{d}{dx}\left(\frac{\partial F}{\partial y'}\right)=0[/tex]
[tex]A=\int_0^{2\ell}2\pi r(z)\sqrt{1+r'(z)^2}dz.[/tex]
[tex]\frac{\partial F}{\partial r}=\sqrt{1+r'^2}\,,\,\,\,\,\,\,\,\,\frac{\partial F}{\partial r'}=\frac{r(z)r'(z)}{\sqrt{1-r'^2}}\,,\,\,\,\,\text{and}\,\,\,\,\,\,\frac{d}{dz}\left(\frac{\partial F}{\partial r'}\right)=\frac{1-r'^4+rr''}{(1+r'^2)^{3/2}}[/tex]
[tex]\frac{1+r'^2-rr''}{(1+r'^2)^{3/2}}=0.[/tex]
If we disallow the denominator from vanishing, we can simplify this:[tex]1+\left(\frac{dr}{dz}\right)^2-r(z)\frac{d^2r}{dz^2}=0.[/tex]
