Surplus of Y on the wrong side
  1. Jan 25, 2005 #1
    How can the following type of equation revolved ? I don't know how to deal with the surplus of Y on the "wrong" side :grumpy:
    dY/dx = aY(1-Y/b)
    a and b are constant. And when X = 0, Y = something.
    I would really like to know how this kind of equation can be resolved :confused:
  3. Jan 25, 2005 #2
    AKG
    Separation of Variables:
    [tex]\frac{dY}{dx} = \left (\frac{a}{b}\right ) \left (Y(1 - Y)\right )[/tex]
    [tex]\frac{dY}{Y(1 - Y)} = \frac{a}{b}dx[/tex]
    [tex]\int \frac{dY}{Y(1 - Y)} = \int \frac{a}{b}dx[/tex]
    [tex]\int \left (\frac{A}{Y} + \frac{B}{1 - Y}\right )dY = \frac{a}{b}x + C[/tex]
    where A and B are constants that need to be solved for. It's easy to see that A = B = 1, so:
    [tex]\int \left (\frac{1}{Y} - \frac{1}{Y - 1}\right )dY = \frac{a}{b}x + C[/tex]
    [tex]\ln (Y) - \ln (Y - 1) = \frac{a}{b}x + C[/tex]
    [tex]\ln \right (\frac{Y}{Y - 1}\right ) = \frac{a}{b}x + C[/tex]
    [tex]\frac{Y}{Y - 1} = \exp \left (\frac{a}{b}x + C\right )[/tex]
    [tex]\frac{Y}{Y - 1} = De^{\frac{a}{b}x}[/tex]
    where [itex]D = e^C[/itex]. Some algebra gets you to:
    [tex]Y = \frac{D}{D - \exp (-\frac{ax}{b})}[/tex]
    There may be some cases where this solution is not valid, i.e. in the steps above, I may have divided by zero if Y = 1 or Y = 0 in some places, you can check the algebra. In fact, the above solution only holds in the case that Y is neither 0 or 1, since Y = 0 and Y = 1 are solutions on their own. Note:
    If Y = 0 or Y = 1, it is a constant, so dY/dx = 0. Also, it is clear that aY(1-Y)/b = 0 for those Y values, as we would expect.
    Now, you say that you have, "when X = 0, Y = something." This is an initial value problem. With this, you can solve for D explicitly (in terms of a, b, and other constants).
  4. Jan 26, 2005 #3
    But it is not...
    [tex]\frac{dY}{dx} = \left a \left (Y\frac{(1 - Y)}{b}\right )[/tex]
    It is...
    [tex]\frac{dY}{dx} = \left a \left (Y \left (1 - \frac{Y}{b} \right ) \right )[/tex]
    ...is there a place where i could get explanations on that step;
    [tex]\int \frac{dY}{Y(1 - Y)} = \int \left (\frac{A}{Y} + \frac{B}{1 - Y}\right )dY [/tex]
    And thank you for your help, i think theses problems (of mathematical ecology) are a little too advanced for my level but it's very interesting. Is there a good book on calculus (that can explain these kind of problems) you recommend ?
  5. Jan 26, 2005 #4
    dextercioby
    Your equation is
    [tex] \frac{dY}{dx}=aY-\frac{a}{b}Y^{2} [/tex]
    and can be inetgrated by separation of variables
    [tex] \frac{b}{a}\int \frac{dY}{Y(b-Y)} =\int dx [/tex]
    Pay attention with dividing through 0...
    Daniel.
  6. Jan 26, 2005 #5
    AKG
    Oops, my mistake. Anyways, if you're familiar with separation of variables, then you should be able to do that.
    That uses a technique of integration known as integration by partial fractions. The book I had for class last year was called, I believe, "Calculus" 5th or 6th edition by James Stewart. There are two versions, one of them is multivariable (with a red/purple violin on the front) and a single variable one (with a greenish violin). Get the multivariable one. Chapter 7 contains techniques of integration. That book covers basic introductory calculus, integration, functions of several variables, vector calculus, first and second order homogenous and non-homogeneous linear differential equations, techniques of integration and differentiation, applications, etc. It's a good book.
  7. Jan 27, 2005 #6
    Thank you AKG and dextercioby, i should be ok.
    Only now i'm addicted to TeX (which seem to be a good thing), is there a Word-like program to write text along with TeX like on this forum ?
  8. Jan 27, 2005 #7
    AKG
    MS Word has an equation editor. You might have to download and/or buy it if it doesn't already come with your version of Word.
  9. Jan 28, 2005 #8
    I'm still stuck... the worst is that i know what the answer is, even if i have no clue how to get to it.
    [tex]\frac{dY}{\left Y (1 - \frac{Y}{b} \right )} \right = adx[/tex]
    [tex]\int \frac{dY}{\left Y (1 - \frac{Y}{b} \right )} \right = a \int dx[/tex]
    [tex]\int \frac{1}{Y} - \frac{1}{Y-b}dY \right = ax + C[/tex]
    [tex]\int \frac{dY}{Y} - \int \frac{dY}{Y-b} \right = ax + C[/tex]
    [tex]\ln Y - \ln (Y-b) \right = ax + C[/tex]
    [tex]\ln \frac{Y}{Y-b} \right = ax + C[/tex]
    If when [tex]X = 0, Y = Y_{0}[/tex] then;
    [tex]C = \ln \frac{Y_{0}}{Y_{0} - b}[/tex]
    [tex]\ln \frac{Y}{Y-b} \right = ax + \ln \frac{Y_{0}}{Y_{0} - b}[/tex]
    [tex]e^{\ln \frac{Y}{Y-b}} \right = e^{ax + \ln \frac{Y_{0}}{Y_{0} - b}}[/tex]
    [tex]\frac{Y}{Y-b} \right = e^{ax}+ \frac{Y_{0}}{Y_{0} - b}[/tex]
    In theory, it's possible to get from there and to go to ;
    [tex]Y(x) = \frac {Y_{0} b e^{ax}}{b + Y_{0} \left (e^{ax} - 1 \right )}[/tex]
  10. Jan 28, 2005 #9
    AKG
    The first thing to take care of are the "special" solutions, which you can find directly by analyzing the first equation. Note that if Y = b or Y = 0 (as constant functions, so Y(x) = b or 0 for all x), then clearly dY/dx = 0, and also the right side is zero, so these are solutions. Now, consider solutions where Y is never b nor 0.
    Now, I'm not sure if you're second last line is a typo or not, but it should not be:
    [tex]e^{ax}\mathbf{+}\frac{Y_0}{Y_0 - b}[/tex]
    rather, it should be:
    [tex]e^{ax}\mathbf{\times }\frac{Y_0}{Y_0 - b}[/tex]
    So:
    [tex]Y = \frac{b}{1 - \exp (-ax)(\frac{Y_0 - b}{Y_0})}[/tex]
