Homework Help: SVD and orthonormal bases
  1. Apr 4, 2015 #1
    Problem:
    Suppose u1,...un and v1,....vn are orthonormal bases for Rn. Construct the matrix A that transforms each vj into uj to give Av1=u1,....Avn=un.
    Answer key says A=UV^T since all σj=1. Why is all σj=1?
  3. Apr 5, 2015 #2
    Fredrik
    Staff Emeritus
    What does the fact that the two bases are orthonormal tell you about A? Can you use the answer to that somehow?
  4. Apr 5, 2015 #3
    I regrouped and thought about this...
    if A=UΣVT then AV=(UΣVT)V = UΣ
    If Σ=I then AV=U and σ=1.
    I think that is it. Thoughts? Much thanks.
  5. Apr 6, 2015 #4
    Fredrik
    Staff Emeritus
    This is correct, but your argument looks kind of circular. It looks like you had been told that ##\Sigma=I## because all the ##\sigma_i## are 1, and wanted to know why all the ##\sigma_i## are all 1. Now you're saying that they're all 1 because ##\Sigma=I##. You can use ##\sigma_i=1## to explain ##\Sigma=I##, or you can use ##\Sigma=I## to explain ##\sigma_i=1##, but you can't do both.
    You're using a theorem that tells you that ##A=U\Sigma V^T##, and also defines ##U##, ##\Sigma## and ##V##, right? How does that theorem define ##\Sigma##? If it defines it as a diagonal matrix with the singular values of ##A## (=eigenvalues of ##\sqrt{A^*A}##) on the diagonal, then I would recommend that you ignore the theorem until you have figured out what the problem statement is telling you about A (and about ##A^*A##).
    By the way, the appropriate place for a question about a textbook-style problem about linear algebra is the calculus & beyond homework forum.
  6. Apr 6, 2015 #5
    Sorry about the misplaced post. I wasn't working with the idea that Σ=I and thus σ=1 or vice-versa. I was working with the idea that AV has to equal U and the only way that could occur is if Σ=I. Even so, I accept your challenge of trying to dig deeper into the problem and so far, I have come up with the following:
    Av1=u1 means that u1 is a linear combination of the columns of A
    but u1 is part of a basis set, so by definition it cannot be made up of other bases. Therefore, A is a projection matrix. (Not sure about this, gotta think about it a little more...just thought I would include my thoughts.)
  7. Apr 7, 2015 #6
    Fredrik
    Staff Emeritus
    It does, but I don't think this will help you find the property of A that I had in mind.
    This is not correct. In fact, the only projection that takes an orthonormal basis to another is the identity map.
    I'll give you another (small) hint: Start by writing down the formula that says that ##\{u_i\}## is orthonormal.
  8. Apr 9, 2015 #7
    Okay, here is another kick at the can. If I want a matrix A that takes V and transforms it into U, such that AV=U where V and U are matrices whose columns are the orthonormal vectors ui,...un and vi,.....vn respectively, then I can isolate for A by taking the inverse of V, so that A=UV-1 but because V is orthonormal then A=UVT. So, if U and V are rotation matrices, then A would be the combination of those rotation matrices. I checked it with some 2x2 matrices and it seemed to work. Thoughts?
  9. Apr 10, 2015 #8
    Fredrik
    Staff Emeritus
    This is correct. (Not exactly the method I had in mind, but close enough. We can discuss my method later). Now what does ##A=UV^T## tell you about the singular values of ##A##? What is your book's definition of a singular value?
  10. Apr 12, 2015 #9
    Well, my book and other readings from the internet seem to suggest that a singular value is similar to an eigenvalue. However, a singular value is a value which multiple an orthonormal basis to get the product of another orthonormal basis and a matrix A. ##A=UV^T## seems to suggest the singular value is 1. Question: Is the singular value always 1 in a SVD? It seems to be the case because the basis vectors U and V are always orthonormal.
  11. Apr 13, 2015 #10
    Fredrik
    Staff Emeritus
    According to "Linear algebra done wrong" by Sergei Treil (which can be downloaded for free online), the singular values of ##A## are the eigenvalues of the operator ##|A|##, defined by ##|A|=\sqrt{A^*A}##, where ##A^*## is the adjoint of ##A##. Knowing this makes it very easy to find the singular values in your problem (where ##A## takes one orthonormal basis to another).
    If this isn't how your book defines them, then it must have provided some other definition, or at least a way to calculate them.
Have something to add?
Draft saved Draft deleted
